Neither do I. The fact is that I rarely use unsharp mask sharpening anymore. I like AI sharpening (properly controlled) better.
Well, that's news to me. I wasn't aware that there's such a thing as "AI sharpening".
It's been around for some years. Adobe, ON1, Skylum, and Topaz Labs all offer it. There are also web-based apps and mobile apps that use it. DxO has a proprietary sharpening method that's not AI powered, but is based on analysis of how specific cameras and lenses perform, applying different sharpening in areas where the sharpness of the lens itself differs.
Thanks. I'll have to look into that.
.... john
If you have Photoshop, use the Smart Sharpen Tool. It’s found in the Sharpen menu tab under Fikyer. Path: Filter>Sharpen>Smart Sharpen. You can change the Amount, Radius, and Reduce Noise values, but I leave them at their default settings. You can also choose between removing Gaussian Blur, Lens Blur, or Motion Blur. And you can also choose separate Fade Amount, Tonal Width, and Radius values for Shadows and highlights. Again, 99.5 times out of 100 I don't touch the Shadow and Hight values.
My preferred way of using it is to first do all of the other processing steps a photo requires (raw processing + whatever post-processing steps in Photoshop that I found necessary) and if that involved creating layers in Photoshop, creating a new layer at the top of the layer stack* and then applying the Smart Sharpen filter. This allows me to decide where I want and do not want the effect applied by creating a mask (when painting in a mask, white reveals the effect and black conceals it), and control how intensely the effect is applied by adjusting the opacity of the layer.
Here are four examples of how Smart Sharpen's default affect the appearence of an image.
1. Before applying Smart Sharpen
2.) Smart Sharpen Default Setting (Lens Blur)
3. Smart Sharpen, Gaussian Blur (Default settings)
4. Smart Sharpen , Motion Blur (default settings)
To be fair , there was no motion to be cancelled in that last example !
The base image I used is a full-resolution 770x770 pixel crop from a focus-stacked ( 13 frames) 45MP raw image shot with a Nikon Z7 II camera and a TTArtisan 75mm f/2 lens. Exposure settings: ISO 64, 1/60th second, f/5.6. The raw NEF file ws processed in Lightroom Classic and exported as an 8-bit TIFF in the sRGB color space. These examples were then saved as level 12 JPEGs after processing in Photoshop Beta (release 27.0.0)
Now for the big question, do you or I need to do any of this? For most photos, no.
*applying anything other than mild capture sharpening to a raw file sharpening and then doing more post processing on top of that raises the risk of creating nasty artifacts if you are working with 8-bit files.
Ellis Vener
To see my work, please visit
http://www.ellisvener.com
I am on Instagram @EllisVenerStudio
