Panasonic's documentation in any available G9 manuals is scant and uninformative, at best, when it comes to the Starlight AF function. I have done considerable experimentation to develop a reliable procedure to get Starlight AF to work, and to understand not only the "how", but the "why", as well. It starts with understanding how this function works. I found an article on Panasonic Australia's blog site that was quite enlightening.
Engaging Panasonic Starlight AF:
Here's how to invoke the process:Member said:From: https://blogs.panasonic.com.au/consumer/top-tips-for-astrophotography-with-lumix/.
Starlight AF
Focusing on low-light subjects can be extremely tricky in any scenario. Astrophotography is no exception, with a photo of the night sky that is even slightly out of focus likely to lose its dramatic appeal. For decades, manual focusing was the only technique to focus a camera when shooting astro, leading to the misconception that manual focus always delivered the sharpest results. Starlight AF challenges this belief, delivering real world results to back up its capability. Equipped in LUMIX cameras such as the S5, GH6, GH5M2 and G9, Starlight AF temporarily ramps-up the ISO to create a brighter scene giving the AF system more information to be able to successfully lock focus and ensure your stars are pin-point sharp.
- The camera should (optionally) be mounted on a tripod for stability in long exposures with image stabilization turned OFF when using a tripod.
- Set AF to AFS, AFF or AFC.
- Place the AF box in the center of the viewfinder or monitor.
- Visible stars need to be located within the AF box.
- Half-press and hold the shutter release (or cable release) to activate the LOW indicator ~2 seconds after the shutter button has been half-pressed and held, presuming that one is in a low-light situation.
- Once the LOW indicator is showing in the viewfinder or monitor, continue half-pressing the shutter release (or cable release) to activate Starlight AF if a detectable star is inside the elevated ISO sensor area.
- If there is no star subject matter visible inside the elevated ISO sensor area, four box corners delineating the elevated ISO sensing area (approximately half the area of the viewfinder or monitor) should appear in the viewfinder or monitor 4-10 seconds after the shutter button has been half-pressed and held, depending on the focal length of the lens in use. The box corners will be red indicating that focus is not achieved.
- When the camera finds star subject matter within the sensing area, the four red box corners will turn green indicating that focus has been achieved, and the STAR indicator will be visible.
- Once the desired subject is within the green box corners and the STAR indicator has activated in the viewfinder or monitor indicating that is is in focus, fully press the shutter button.
- Red blinking exposure values > proper exposure is not achieved
- Red square/blinking green dot > focus is not achieved
- Green square/solid green dot > focus is achieved
- Half-press does not work from the Lumix Sync app.
- Half-press has been mentioned above, but Back Button Focus, AF ON: Far Shift and AF ON: Near Shift will work as well, and must be fully pressed and held down until STAR appears.
- Note that the lens focal length may affect the length of time to see the green box corners as it increases, but in any case, maintain the shutter half-press until the green box corners appear, and continue the half-press until STAR appears.
