ainsoph
Well-known member
Hey, sorry if this isn't the right place, but I'm trying to make some 8' tall moveable, mobile walls for my photo studio, and am trying to figure out the best way to go about it. I think it would help me with repeat rentals, having a different setup often, and would kill my creative rut.
Requirements (ideally):
1. 4'x'8 panels
2. Lightweight, enough to move daily if need be
3. Paintable/attach-to-able
4. Free-standing AND mountable
5. Flush with the floor
6. Ideally double sided so that I wouldn't have to paint as often.
7. Smooth surface, not obvious wood grain
So, I want to have them act as a mock wall against the wall that's already there 90% of the time, but would like to be able to stand them and make a little room or whatever when it's called for. The obvious solution is to put them on wheel, but if they're on the bottom, they won't be flush with the floor, and if on the back, they won't be close enough to the wall to be discreet.
My current best solution:
Four 3/8" thick 4'x8' PVC panel boards. I'm thinking I put a piece of molding along the wall, and sort of hang them from that the way you would a picture frame? So I can easily lift them up and off when I need to. Primary concern here is not damaging the wall behind them, so ideally they'd never touch. I figure I could mount some sort of foldable stand on the backs of them that would be hidden when they're on the wall. Two can have door hinges on the back for me to easily make a corner wall when need be.
Second current option. Everything the same, but super thin PVC board, just attached to a thin wood frame.
Think heavy duty Vflats.
Would that thick green hard foam at homedepot work for this?
Didn't want to use drywall, as I want them to not crumble or damage easily, and remain flush together. BUT, I actually know next to nothing about home improvement stuff, so if there's a way to get drywall not to do that and I'm just an idiot, please tell me
If anyone has done or seen something similar, or has any ideas let me know! I feel like what I want is possible, just trying to think outside the box here, and figure out a gameplan before buying an excess of stuff that won't work.
TL
R: I want a moveable prop wall that can be changed as often as need be and be made into smaller/folding walls.
1. 4'x'8 panels
TL
