Hello all, I’ve been trying to do focus bracketing with my 100s camera and GF63 lens mainly in the focus bracketing manual mode. I’m following the instructions I’ve found by pressing the Drive button > Bkt > Focus Bkt > Ok, then Menu Ok > Shooting Settings> Focus Bkt Setting > Manual, pressing Ok and selecting 006 frames, 3 Step, 0 interval and pressing Ok. Then using the display/back button to back out of the menus till I’m seeing the live scene in my camera. From there I’ve tried 2 variations: one is to press the shutter button, the other is to press Ok after setting the focus, and then hitting the shutter button . In either case the camera shoots the 6 frames I had set as a maximum, but they all stay focused on the nearest point I originally focused on . The focus point does not change.
I’ll add I’ve been doing this handheld, as I want to test if using focus bracketing handheld with a smaller number of frames is feasible for landscape shooting. I’m wondering if moving my camera a little after choosing my nearest focus point with back button focus is causing a problem? I have tried the above in MF and AF-S, using touch screen and the joystick and back button focus to select the focus point all to no avail.
I’ve been making my efforts in a medium sized room with spaced furniture and other objects.
I also tried focus bracketing auto mode once and it fired off 47 frames, but once again the focus point did not change. It remained on the original near object .
I’m pretty sure there is some small point or procedure that is blocking things. But after numerous tries and attempts to research it I’m at my wits end. I’ll add I’m using the latest firmware: V2.12 with my 100s and V1.10 with my GF63.
Thanks, anyone’s help will be much appreciated.
