John Sheehy
Noise is often rendered with whitish or bright-ish dots in otherwise dark areas, giving a boost to apparent shadow brightness. Less noise, and the shadows are darker, with the same intended tone curve. I noticed this early on in the days of digital cameras, because clean images need a gamma curve to convert from raw to sRGB (if you want to see the darker areas), but when you have a really high ISO, or you severely under-expose, the brightness created by the "salt" of the "salt and pepper" of noise reduced or eliminated the need for gamma correction.So I keep coming back to an issue I have with "high dynamic range" sensors. When I look at photos on flickr (mostly landscapes) taken with older, poorer dynamic range camera like the 5D II or 5dsr, I am continually impressed with the output. The tonality of images are gorgeous - nice soft shadows, beautiful midtones.
When I look up newer, "better" cameras I often see near-black shadows dominating the image or washed out looking midtones.
I am fully aware, from experience myself, that more DR helps. Having shot old Canon Rebel cameras in the past and fighting to not blow the sky out, I fully get the advantages of newer sensors. What I'm wondering is... Why do I tend to prefer old, lower dynamic range images?
I've got a few theories:
I've seen stunning shots from most every sensor, including many newer ones - I'm definitely not saying more DR is worse. But... Does anyone else see what I'm seeing?
- People bracketed more back then so they had even MORE DR to work with.
- People shot/posted only low DR scenes which... Are just nicer scenes - basically I'm not seeing the ruined shots of old, but I'm seeing people trying to use their full DR now.
- People are lazier with more DR because you don't NEED to be as careful.
- In the 5D III era, full frame was more dominated by pro and experienced photogs, and now we see everyone's work.
Lower DR means more shadow noise, so more of this "salt" effect that brightens shadows.
