Amando Hernández
Leading Member
The G2 is able to go down to 34 mm. instead of 38 mm. for the 707 (in 35 mm. focal distance eq.)
Well, four milimiters don't semm too much, but if you like wide angle photography, that makes a difference.
The same thing can be said about tele. Here, the F707 is a clear winner.
Well, someone would say, buy a tele/wide angle converter if you need an extra reach... I have only tested the Sony WA for the S85 (from 34 to 24 mm.). I wasn't pleased at the result (too heavy, too much barrel distortion, the camera was locked at 24mm.). I don't have any experience with teleconverters.
The G2 eq. in Snoy's terms is the S85.
My two pixels.
Amando
My two pixels.
Amando
I would not make this decision based on any of the reliability
issues discussed on these forums. Both cameras are good enough in
practice. The question I would ask is what style of camera you
want. Do you want something that's somewhat compact, uses an
optical tunnel viewfinder, and has a twist/swivel LCD when you want
to see what the lens sees? Or do you want something a bit bigger,
more like an SLR, with an electronic viewfinder and bigger lens
that has more reach? If you actually try using both cameras in a
shop, you'll soon find yourself gravitating towards one or the
other.
Peter Epstein
