vineviz
Well-known member
Two things on this sentence. First, it is not an exclusive statement. In other words, Canon is not asserting that other lenses ARE NOT "designed and built" to meet the needs of demanding photographers. Second, it probaly refers more to mechanical quality than optical quality.The last paragraph from:
http://www.usa.canon.com/eflenses/technology/lseries.html
"Canon L-series EF lenses are designed and built to meet the needs
of the most demanding professional photographers.
This is true, but is also full of marketing hyperbole. The focal length/aperture combinations of the L-series lenses (especially zooms and super-bright primes) probably is unattainable using traditional technology. That just tells us that a usable 50mm f/1.0 be impossible to build without a ground and polished aspherical element, for example. It doesn't tell us that the 50mm f/1.0 will outperform a 50mm f/1.4 at similar apertures. This may be true, but that isn't what Canon is asserting here.Their superb
optics enable pros and advanced amateurs to have lenses that are
the absolute pinnacle of optical performance, and enable lens/speed
combinations with professional performance simply not attainable
using traditional optical technology."
That chart is showing us that, according to Castleman, at the 135mm focal length, the 135mm f/2L and 70-200 f/2.8L outresolve the Tamrom and Canon consumer zooms.Also, if I look at this link, it is pretty clear that the L lenses are superior to the consumer lenses.
The chart below shows that the 50mm f/1.4 outresolves the 28-70mm f/2.8L at 50mm. If you look carefully, you'll also note that the 24-85mm f/3.5-4.5 outresolves the 28-70mm f/2.8L at f/8
The chart below shows that the 24mm f/2.8 outresolves the 17-35mm f/2.8L almost across the board. So does the 24-85mm f/3.5-4.5
Of course, these are simply resolution tests. There are dozens of other factors that one might consider when evaluating a lens (sharpness, contrast, bokeh, maximum apeture, size, weight, cost, distortion, chromatic aberration, spherical aberration, flare, astigmatism, curvature of field, coma, etc) that might lead a person to prefer the L to the non-L or vice versa.
