Thanks, guys.
I think I know the answer to this, but can you help me get clear on it?
I'm assuming that even the a9III's global shutter won't solve the problem of large panel digital displays, because they scan/refresh at 50/60Hz and the only way to capture the entire screen without ghastly moiré is to use a shutter speed of 1/60s or longer. Does this sound right? Would an a9II or a1 help here? Any real-world experience to confirm this?
I recently shot a conference where the entire backdrop behind the stage was a huge grid of these panels, and it was a real bugger. Prevented me from shooting at a distance because the required slow shutter (WITH full mechanical shutter) ruled out long focal lengths with moving subjects onstage, so I had to shoot from the middle of the audience instead of the back of the room, and some grumpy old mushroom chewed me out for obstructing the view. Argh!
I have used the A9iii on a few occasions, and it didn't have any banding issues no matter what kind of light I was dealing with, including these LED displays.
Not only does it capture its image data instantly, it has some clever software checking the frame for flicker - including LED flicker - and taking a few frames insanely fast, then only keeping a frame with no flicker.
I don't know how it does that exactly, but in my experience, it works flawlessly: You point the camera, take the shot, and it will magically be entirely flicker free under all circumstances.
I tested it at a couple of venues alongside my old A9, and where the A9 had banding, the A9iii never did.
The A1 should be able to detect flicker and adjust automatically to avoid banding, and the 1/250s sensor scan speed helps significantly.
But there are venues where you have multiple LED lights all flickering at wildly different frequencies, and no camera can adjust for every single one of them. The A9iii doesn't have to, the rest do.
In a worst case scenario, the kind of LED wall with multiple displays you encountered could have different flicker rates in different parts of the wall at the same time.
In technical terms, unlike old school flicker, LED flicker isn't 50/60 Hz, and it has nothing with AC/DC frequency to do.
LED flicker is caused by dimmers which reduce LED brightness by rapidly turning the light on and off (pulse width modulation, PWM).
This is invisible to the human eye and simply looks like reducing brightness. But cameras can see it. It only becomes an issue with certain kinds of dimmers, some are capable of producing very dim light with no banding.
It's criminal that not only are LED light manufacturers getting away with it, they typically don't even tell the buyer which refresh frequencies their lights can exhibit.
And all because the only person affected by it is the photographer. It doesn't seem to affect mobile phones, presumably because their sensors are tiny with extremely quick scan times.
Since I can't afford an A9iii and I will have to deal with LED banding from time to time, I take some extra shots when I notice banding, because typically, the brightness of the LED lights/displays goes up and down all the time - so even if there is banding in some photos, chances are, there won't be any just seconds later.
More rarely, I can take the shot at a lower shutter speed, fixing the problem. Rarely an option for me because my subjects tend to move fast.
www.luxpraguensis.com
