sweep pano not getting all of image - you too?
Actually, it was mentioned in the manual. The initial frame where you position the camera is not included in the image. Always start another frame to the left or right before you start. The width coverage could be selected from the menu. There are 2 different ratio you could choose.
I've tried sweep pano a few times on my A55, and I've noticed:
  • it does not include the frame as shown in the viewfinder (lops off up to 1/2 of vertical height, either at the top, bottom or both)
  • it doesn't sweep as far as I'd like ... even though shutter sounds are still going, it omits the last several images.
  • sometimes the match or blending is bad - a clear vertical line shows two separate images not blended or adjusted.
Sample below.
Are you having any of these issues?
Have you found some tricks or solutions?
Can one make the image size smaller (8mp not16mp) and get longer sweep?
As it is now, a series of shots then using pano software gives far better result. Sigh.
Music Hands
