My first experiments with measuring MTF were done following Erik's suggested method here:
https://www.dpreview.com/forums/post/65122260 This involved shooting slant edge test targets, opening in LR, cropping to the desired region of interest and exporting the region of interest as a tiff which was then loaded into MFT Mapper using the "single edge" option and analysed
Today, while playing with the program, I discovered that it can directly open and process raw files (dependencies with dcraw appear to be built in, so nothing special needs to be done other than selecting a raw file and opening it).
I also discovered the "manually select the slant edge" to measure option.
I've been playing with these using the exact same files I shot my first run of tests on. Because the test target is quite small in my frames, I have to zoom in and mark the slant edge region of interest.
Here's the interesting bit: using the raw file directly and doing the ROI selection manually rather than first cropping the file to tiff and letting the software select the ROI appears to yield higher MTF scores than the first method.
With the exact same test files as the source.
Example: With my 90mm Sonnar, using the second method yielded a score of 59 lp/mm while the first method gave 23 lp/mm
That seems a bit odd to me.
Any ideas about what is going on?
