ghostfox_1
- Messages
- 3,134
- Solutions
- 5
- Reaction score
- 6,168
Why?X-type AF sensors are desperately needed in these FF bodies.
I have the Z6, Z6ii and Z9 and even with the Z9 eye-AF will still not nail focus every time. In fact it's going to be ever so slightly off more often than nailing absolute focus but because everything is still in the depth of field range of acceptable focus, it'll still work.This is interesting. I have seen other posts on the 'Z' eye-AF issue and it seems different people have very different experiences. Not sure why this is, could it be it depends on the lighting, age or other factors of different subjects?...type of lighiting? no idea.I also have the bottom of the line Z5 full frame camera and eye focus works great, near perfect, for still non moving portraits in decent to good lighting, 1 person at a time and group portraits. I don't use Z5 for sports or fast moving subjects. For those and events, I use the Z9.I think you have a point. It wouldn't surprise me if the Z6/7 with "proper" firmware could do a significantly better job on eye-AF. I use a Z6 and basically don't use eye-AF at all. I get a very high hit rate with single point focus and "focus a recompose". I get that if your subject is moving that won't work so well, but for static portraits it works great.Canon, for example, has clearly not needed stacked sensors to have vastly improved AF in their two new sub-$1500 models. So maybe it's just about the programming, and not so much about the sensor tech?
I will ask you this, since you have both the Z5 and Z9, how would you compare their eye-AF performance for non-moving subjects (e.g. portraits). My experience is with a Z6 with latest firmware and it is near unusable. Even if the little yellow box finds the subject's eye, many times (maybe most times) the eye will not be in focus. That has been my experience.
If this happens with various people and lenses then it is definitively a "you" issue. E.g. due to shooting humans with shutters speeds below 1/125s or other crazy settings (like handheld AF-S at f/1.2 only). If you are always using the same lens, maybe there is the issue.I will ask you this, since you have both the Z5 and Z9, how would you compare their eye-AF performance for non-moving subjects (e.g. portraits). My experience is with a Z6 with latest firmware and it is near unusable. Even if the little yellow box finds the subject's eye, many times (maybe most times) the eye will not be in focus. That has been my experience.
today had 630pm photo shoot. Golden hour. Was using Z5 for still portraits. Eye focus worked well. I have latest firmware on my camera. Not sure ifThis is interesting. I have seen other posts on the 'Z' eye-AF issue and it seems different people have very different experiences. Not sure why this is, could it be it depends on the lighting, age or other factors of different subjects?...type of lighiting? no idea.I also have the bottom of the line Z5 full frame camera and eye focus works great, near perfect, for still non moving portraits in decent to good lighting, 1 person at a time and group portraits. I don't use Z5 for sports or fast moving subjects. For those and events, I use the Z9.I think you have a point. It wouldn't surprise me if the Z6/7 with "proper" firmware could do a significantly better job on eye-AF. I use a Z6 and basically don't use eye-AF at all. I get a very high hit rate with single point focus and "focus a recompose". I get that if your subject is moving that won't work so well, but for static portraits it works great.Canon, for example, has clearly not needed stacked sensors to have vastly improved AF in their two new sub-$1500 models. So maybe it's just about the programming, and not so much about the sensor tech?
Well I was using strobes and my shutter speed was 1/200th, opening f/8. When I used eye-AF, terrible results. When I used single point AF....flawless. It was an adapted Canon lens, but since it worked fine with single point AF, seems like it should have worked with eye-AF as well.If this happens with various people and lenses then it is definitively a "you" issue. E.g. due to shooting humans with shutters speeds below 1/125s or other crazy settings (like handheld AF-S at f/1.2 only). If you are always using the same lens, maybe there is the issue.I will ask you this, since you have both the Z5 and Z9, how would you compare their eye-AF performance for non-moving subjects (e.g. portraits). My experience is with a Z6 with latest firmware and it is near unusable. Even if the little yellow box finds the subject's eye, many times (maybe most times) the eye will not be in focus. That has been my experience.
I am the first one to flame the Z5/Z6/Z7 for their lousy AF speed, but the actual accuracy on static subjects is far from "unuseable" but actually pretty decent. The Z5/Z6/Z7 (II) are not really fun on moving targets due to the missing speed though.
If you are using proper settings, please share some examples.
True.If this happens with various people and lenses then it is definitively a "you" issue. E.g. due to shooting humans with shutters speeds below 1/125sI will ask you this, since you have both the Z5 and Z9, how would you compare their eye-AF performance for non-moving subjects (e.g. portraits). My experience is with a Z6 with latest firmware and it is near unusable. Even if the little yellow box finds the subject's eye, many times (maybe most times) the eye will not be in focus. That has been my experience.
I shoot handheld, the 85mm F1.8 S wide open at F1.8, the eye AF works well on my base Z5 body. Humans at 1/100th second. During a photo shoot today at 645pm, golden hour. Tack sharp, great results.or other crazy settings (like handheld AF-S at f/1.2 only). If you are always using the same lens, maybe there is the issue.
Because having sensors that only see one axis of detail creates alot of false positives, or even scenarios where the camera can't lock at all, so you have tilt the body to get a lock. It's actually super frustrating, especially when shooting in really dark situations.Why?X-type AF sensors are desperately needed in these FF bodies.
The Z9 has, to my knowledge, no dual processors. It only has one EXPEED 7 processor (the Z6/Z7 mark II models have dual processors of the previous generation).According to pcmag.com:
<snip>... We've seen some cameras hit 30fps (the Sony a1), and the Nikon Z 9 manages 11MP photos at 120fps because of its stacked chip and dual processors. </snip>
Does it though? The machine learning handles things pretty well, and unless you're shooting a subject with no contrast and literally 0 vertical detail the af system will find something.Because having sensors that only see one axis of detail creates alot of false positives, or even scenarios where the camera can't lock at all, so you have tilt the body to get a lock. It's actually super frustrating, especially when shooting in really dark situations.Why?X-type AF sensors are desperately needed in these FF bodies.
You're correct.The Z9 has, to my knowledge, no dual processors. It only has one EXPEED 7 processor (the Z6/Z7 mark II models have dual processors of the previous generation).According to pcmag.com:
Yes. I have no problems on the Z9.Regardless of how it is done, I think we can all agree improved AF is needed. Okay, maybe owners of Z9 disagree.
Z9 has EXPEED 7. The most powerful Nikon processing engine ever. 10x faster than Z7ii previous generationsThe Z9 has, to my knowledge, no dual processors. It only has one EXPEED 7 processor (the Z6/Z7 mark II models have dual processors of the previous generation).According to pcmag.com:
Nor me and I have two Z9.Yes. I have no problems on the Z9.Regardless of how it is done, I think we can all agree improved AF is needed. Okay, maybe owners of Z9 disagree.
Well, yes, if your subject has literally 0 horizontal detail, but this never happens in the real world (and if it does, I'd love to see examples). Even branches have some. I never had this problem with my 7 or 9 in real world use.Yes !!
Z9 AF still cannot achieve some performances that olders DSLR AF can.
Just look at what Nikon says in its Z9 Reference Guide as limits of the Z9 AF ( hidden somewhere in the chapter troubleshootings and solutions)
As example try to focus on lines ( electric wire of horizontal branch wating a bird or any line paralle to the AF pixels lines : null chance)
I have. It works fine, and did with my z7 as well. The issue is being steady enough to keep the af point on it.Second example : try to focus on a bird through a little hole beetween branches using the smallest and accurate Single focus point or 3D pioint and compare with what the D850 can achieve in term of accuracy (smallest focus surface non troubled by surounding context or foreground) .
Very rarely, and usually only if your subject has 0 contrast and the background has a lot and you're way off focus in the first place.Z9 with medium-long lenses remains sticked very frequently on the back ground without any hope to come back for focusing on the point you want under the properly and stabilized red focus square you place carefully on a smaller subject.
No. They're mostly user side issues.All of these are only due to the lower capability of OSPDAF technology.
But Sony and Canon either have these same problems, at which point you should mention it, or they don't, which means the tech is fundamentally solid. Which is it?So lets hope Nikon will renew with its own AF inventive designs rather to follow only Sony ( or Canon) sensors fashion.
The disadvantages of Mirrorless AF over DSLR are vastly overplayed and overwhelmed by the advantages -- not least of which is 3D-tracking with Subject Detection, almost full sensor coverage and the large array of choices one can access immediately via programmable FN buttons.Well, yes, if your subject has literally 0 horizontal detail, but this never happens in the real world (and if it does, I'd love to see examples). Even branches have some. I never had this problem with my 7 or 9 in real world use.Yes !!
