Michael Fryd
There are two types of waste being talked about:Simoly wrongAll sensors waste a part of the image circle when the aspect ratio of the sensor doesn't match the aspect ratio of the final image.But...
With FF lenses, it is still not optimal !!! Why wasting some part of the image circle for every ratio different from 3:2 ?? So we buy expensive lenses and we don't take full advantage of them because the sensor is not big enough...
- Light that's part of the image circle that doesn't hits outside the sensor
- Pixels on the sensor that don't get used in the final image
The 2:3 aspect ratio sensor that makes the best use of the image circe is one where the four corners hit the edge of the circle.
A full frame camera has a sensor size of 24 by 36mm, and a 2:3 print uses all of it. If we want an oversize sensor we could use 36 by 36mm. However this does not allow a 2:3 print to use any more of the image circle, and it results in wasted pixels in that 2:3 print.Not correct.If your final image will be in the 2:3 aspect ratio, then a 2:3 sensor will make the best use of the image circle. If you final image will be a square, then a square is better. The sensor aspect ratio that is best in the general case is the one that matches the typical image.
Just use an oversized sensor. Besides it does not require to be much bigger.
In terms of efficiency, it may seem that for a variety of aspect ratio prints, that a the largest square that fits into the image circle provides the least waste overall. However it doesn't work out that way. Square is the most efficient when the prints are square, and inefficient for wider aspect ratios. The most overall efficient is the one that somewhere in the range of aspect ratios. If you typically shoot anywhere from square to 16:9, then you want something between the two.
