KIM MIN-SU
Well-known member
I agree your opinions,
The noise is so critical issue for me and others.
but, I want to say about the primary color performance.
I got a sampe photo in my room.
captured with My SD9
In case of sd9, more accuracy mixed color
captured with My S2Pro
In case of s2pro, more accuracy color
can't display the clean red color in my photo taken by SD9.
I have been tried to get the clearn red, blue and green color.
but, in lighter area, color is changed to the other color feeling.
and in dakrer area, color is red, but too dark and dirty,
SD9 with 24-70DG2.8
----Ok,
I can undertand your opinions.
and I have a TRV2000 (sony, 3CCD DV) and I have been test the same
image without trouble.
Color temperature is not same as the target via media such as film,
CCD, CMOS or others.
BUT, I want to say about
(1) Abnormal color changing via intencity
(2) Abnormal gray color changing in high intencity area.
AND, I want to say about
(1) How can understand about the color difference
between low intencity area and high intencity area.
Check this sample image
It's a test pattern to check the color
It's a decompressed raw data.
In this test, can't found the color change. OK?
It's a relative intencity of sensor information with green light
source
It's a relative intencity of sensor information with red light source
It's a relative intencity of sensor information with blue light source
The relative intencity via light level and properties were measured
with the colored light source have no problems.
but, color changing is a problems (be occured by the color
separation process).
Color problems is appreared only in HIGHER light level.
To avoid this problems, Default light level of SD9 is so low.
I am falling in puzzle,
(1) to get the color, I overcome the noise problems
(2) to get the clean image, I overcome the color problems.
27-70mm/2.8, ISO100, 1/10S, F4.0
color temperature of source = 6800k
http://www.pbase.com/dgross
ICQ UIN: 289647506
SD9 with 24-70DG2.8
