OutsideTheMatrix
- Messages
- 11,895
- Reaction score
- 3,377
I found these two solar filters from B&H that cut out UV and IR (note they still warn not to use them for visual use-- only photographic!)
They're somewhat more expensive than the filter I'm getting but still reasonable (75-79 dollars in the 58mm size.) I'd personally go for the NiSi, it looks better to me. The Tiffen isn't on Amazon, the NiSi is, but only in 77/82/95mm size.
https://www.bhphotovideo.com/c/prod...d54_58mm_neutral_density_filter.html/overview
The 58mm Special 50th Aniversary Edition 18-stop Solar ND Filter from Tiffen is a solid ND filter with a 262,144x filter factor that provides an 18-stop exposure reduction. Its 5.4 density darkens the entire image, allowing you to photograph with a wider aperture or slower shutter speed while reducing the risk of overexposure. This means you can capture more detailed solar images than might be possible under normal conditions. This filter limits IR and UV light, ensuring color-neutral images, and reduces glare with its multi-layer coating.
In honor of B&H's 50th anniversary, Tiffen presents this limited edition run, specially designed to celebrate five decades of creative partnership. This exclusive Special 50th Anniversary Edition embodies the commitment to excellence that B&H stands for. Get your hands on a piece of history with this distinctive edition.
This filter is designed specifically for photography applications. This filter is not suitable for direct solar viewing with the naked eye, including with optical viewfinders.
https://www.bhphotovideo.com/c/prod...FWuPvDpeJmF5BJzDdF2cTuBP1JOvY8lRoCjyMQAvD_BwE
This 58mm Solar Filter Pro Nano UV/IR Cut ND100000 Filter from NiSi is an essential tool for any photographer looking to capture stunning solar images. This high-quality filter is made from optical glass and is designed to provide a 16.5-stop light reduction, making it possible to capture detailed images of the sun without overexposing them. The filter also cuts UV and IR light, ensuring the most color-neutral result. The Nano coating on the filter also helps to reduce reflections and glare, improving the overall image quality.
The NiSi Solar Filter Pro Nano UV/IR Cut ND100000 is essential for capturing stunning solar images that will stand out from the crowd. With its high-quality construction, advanced features, and ease of use, this filter is a must-have for any photographer looking to take their solar photography to the next level.
Precautions and Warnings
https://www.amazon.com/NiSi-ND10000...words=nisi+filters&qid=1711556322&sr=8-5&th=1
About this item
Brand NiSi Material Optical Glass Photo Filter Thread Size 82 Millimeters Coating Description Nano Coating Photo Filter Effect Type Neutral Density Water Resistance Level Waterproof Product Dimensions 3.23"L x 3.23"W Photo Filter Size 82 Millimeters
About this item
- This filter is not appropriate for direct solar observation with the naked eye, and should exclusively be used for photographic purposes.
- Check the solar filter for damage before each use by holding it up to a bright light (not the sun). Secure the filter properly by screwing it fully onto the lens.
- The NiSi Solar Filter is not suitable eye protection for extended view of sun or solar eclipses. Do not look directly or indirectly into the sun without appropriate eye protection. The Solar Filter should be installed in front of the camera lens or telescope before trying to align it with the sun. Point the camera away from the sun when attaching and removing the solar filter.
- Do not use an optical viewfinder when aligning your camera or telescope with the sun. It is recommended to use the live view feature of the camera for aligning it with the sun and for viewing.
- Do not leave a camera unattended where a child or inexperienced adult could point it at the sun without the filter adequately attached.
- The filter may absorb solar energy and get hot during use. Use extra care when removing it.
About this item
- SIZING: Designed with a standard filter thread. Confirm your lens size by locating the "ø" symbol.
- NEUTRAL DENSITY: The 5.0 density reduces the amount of light entering the camera by 16.6 stops.
- COLOR-NEUTRAL: Distortion protection from both ultraviolet (UV) and infrared (IR) light spectrum.
- NANO COATING: Reduces unwanted reflections, waterproof, dust-proof, and scratch-resistant.
- HIGH QUALITY MATERIALS: Premium camera lens optical glass housed in a slim, knurled aluminum frame.
About this item
- With a 16.6-stop light reduction, this filter is perfect for capturing stunning details without overexposing your images
- The filter is designed to cut UV and IR light, ensuring the most color-neutral result when shooting in bright conditions
- The Nano coating helps to reduce reflections and glare, improving the overall quality of your images
- Allow the ND100000 filter to attach to lenses with a filter thread of 77mm (using the Step Up Ring) or directly to an 82mm filter thread.
- Ultra-thin aluminum step-up ring allows for use on 77mm lenses and keeps the filter close to your lens to avoid vignetting.
