The best tripod is the one you have with you. I'm obsessed with ultra-compact, ultra-light gear, and I've tried a LOT of tripods in recent years. After having owned the Peak Design and my most recent favorite Marsace XT-15, this Oben CQL-13 is the one I will be taking in my travel kit.
It is not for heavy cameras or extreme conditions such as high winds or extra tall positions, but it is quite steady for regular use. I use it with my Sony mirrorless full frame with 20-70 lens. The legs extend and retract quickly and securely with the no-collar twist and pull system that I prefer.
The ball head was a surprise- really good quality and low-profile design. The tripod has a more narrow leg angle than some (21 degrees) which increases height but reduces stability. Same with the rather narrow trapezoidal center column. I would not hesitate to do time exposures with the column not extended, and with a weight on the bottom hook.
At under 1.5 lbs, less than 14 inches long (with QR head tilted to side), and less than 3 inch diameter, this is the smallest and best compromise I've found for a "real" (not tabletop) tripod. While not as tall, It's 1.3 lbs lighter and 2 inches shorter when packed than the Peak Design. To me, that's a significant difference. Load Capacity: 13 lb
https://www.bhphotovideo.com/c/product/1765443-STUD/oben_cql_13_compact_carbon_fiber.html
- Working Height Range: 5 to 51.1"
- Folded Length: 14.5"
- 2-Way Ball Head with Arca-Type QR
- 5-Section Carbon Fiber Legs, Twist Locks
- Weight: 1.5 lb
