lewishart
Active member
- Messages
- 56
- Reaction score
- 2
Hi guys, so I have a TC related question.
A lot of my current work is events based, they want live clips of the events for socials. Currently I have a pretty bad system where I record several hours straight of footage on Cfast or ssd.
Use my red Komodo or mostly the Blackmagic4k for the events as file sizes are way more favourable.
Then I have a Zoom H6 Recorder (doesn't have TC built in sadly) that I plug into the sound desk, and then hit rec on that, line up the audio in post and video and then cut away at the best bits.
Now that forces me to literally not stop recording (on both) which isn't ideal at all and makes me chew through video media, so I wanted to see what reasonably cheap option there is for timecoding each device, the tentacle sync, / there's the diety TC1 I believe they are called, both pretty expensive as you need 2 of them as far as Im aware? (total novice to TC never needed in in the past)
Is there any good / cheaper solution for the above besides the above items I mentioned?
Thanks ahead
lewis
Thanks ahead
lewis
