Sensor-Lens modules: the "smart" solution?
Apart from the dust issue, are you asking for more lens modules ... or?
I've noticed nobody posting about any dust issues with their M-mount modules, despite changing lenses (evidently quite a bit). Interesting.
... if Zeiss or Leica would put a Digital Ikon or EM10 (EVIL M) on the market for under $2000, then I'd probably jump ship too, as soon as I can spare the money.
Apparently, your prayers might have been heard - this rumor was posted today:
"It is a real Leica, not a clone or a re-badge. It will cost less than the M9 and feature a regular VF (no EVF and not EVIL). In fact, it’s more like the M9 than it is different – it’s a scaled back M9. M mount."
Source: http://www.mirrorlessrumors.com/
Documensony
'Spontaneity is enabled by rigorous practice'
Couldn't make it for Photokina?
FF sensor for less than $2,000? - I want one too..
Sounds like Ricoh might have a less than $2,000 FF M mount module on the way themself.
Tom Caldwell
I really like using the EVF tilted up. I'm not sure I'd want to use a built in one now. Especially for tripod work which comprises a large amount of my street people photography.
http://clemans-gibbon.com - glamor/studio work (flash site with music)
http://www.flickr.com/photos/71724131@N06 - street/misc photography (mostly with X100 and GXR/M):
Gary, how about a hot shoe mounted "half size" fixed horizontal lcd accessory with flip up light shield?
I think that any tightly intregrated plug in evf in conventional mount would have to be in addition to the present evf as it is certainly too useful to be discontinued. But there is a need also for an "as small as possible" stright-through plug-in evf that is as cleanly fitted and as snag-free as posssible - one that could "live" on the camera safely should it's owner so desire.
Tom Caldwell
Why do you keep pushing the GXR and it's modules like a madman?
Do I? I don't think I do, I don't have any aps-c primes or the A16 zoom. I only have the S10 and P10 as convenient way to get extra camera backs. They have their uses though. I just tried to say that if the present direction of integrating firmware correction of lens performance into cameras gets more sophisticated then it will go beyond a "chip in a lens" or single-camera box into the exchangeable lens category. If this technology modifies lens characteristics beyond the physically-possible then it will be necessary to associate a correction chip at least and possibly a sensor as well into the design. This sounds very much like what Ricoh do already.
If I am understanding this, I think you're saying that a lens might need a chip of some sort to provide correction. If so I think the only thing the chip would do is notify the camera on which the lens is mounted, which lens it is - and the camera would then know in software or firmware how to correct for the lens. I'm not certain how my camera knows which lens I've put on it, but it does, and perhaps already does this exact thing. When I buy a newer body and use the same lenses on it as I have now, any corrections might need to be done differently, or in a different way to suit the new camera's systems. Therefore any image correction should come from within the camera's software or firmware where it is compatible with that camera, that model, that firmware version, etc.
If that is in fact what you said, then excuse me for not understanding.
The GXR as a camera with interchangeable lenses is a failed concept because of the lens modules. You cannot upgrade your sensor without also replacing the lens.
This is the crux of my argument - if a chip and possibly a sensor needs to be associated with a lens then this must happen. If great lenses are expensive then even greater chipped/sensor attached lenses might even work out cheaper.
Once you start matching sensors to lenses I think the the economic factors will go the wrong way. It would be a limited concept anyhow since by far it is lenses that are interchanged on camera bodies with 'fixed' sensors and nobody is clamoring for that to change.
I see this as a non-starter though it can be fun to speculate.
The Micro-FourThirds system protocol includes software lens corrections built into each lens individually. All the body has to do is accept them from the lens and inject them into raw files, or use them to process JPEGs.
So there's an example of an interchangeable lens system with embedded lens correction software that works very well, across a dozen bodies, two dozen lenses, and two manufacturers. The first mFT camera and lenses were released in Nov 2008.
Godfrey
http://godfreydigiorgi.posterous.com
Why do you think that a lens MUST be associated with a particular camera? In today's world, lenses have their own firmware and their own firmware updates. Fujifilm's new interchangeable lens camera uses lens correction and these new lenses will soon be used on other cameras, not the original X Pro 1. If the camera is designed to receive information from the lens, then all is well. There is no need for the lens to be bolted onto the sensor. You get all the advantages of the GXR without all the overpriced, redundant sensors.
Help Fight Disease! http://folding.stanford.edu/English/HomePage
Please join and be part of the solution! Lives can be saved.
I fold under the name RattyM. > 90 Work units completed, BILLIONS of calculations done, all from a Dell laptop. Everyone can be part of the solution. You just have to get started.
... it is lenses that are interchanged on camera bodies with 'fixed' sensors and nobody is clamoring for that to change.
Now, now ... Tom isn't excactly 'nobody' ... :)
Documensony
Common practice for lens and camera manufacturers to correct and enhance existing lenses and provide databases so that the camera is smart enough to know all about it. No contradiction there.
Some years ago some folks dreamed of faster lenses and bigger sensors in smaller bodies.
Those who understood the laws of light rays through optical glass and majored in physics then leapt on to the forums and stated quite loudly that once sensors got to a certain size you needed rather large lens sizes to keep up the "required" specifications.
Basically bigger sensor, faster aperture, longer zoom - they all require progressively larger lenses. Obviously this contradicts the requirement (for instance) that the GRD keeps the same size body but perhaps an aps-c sensor (or maybe even a 1" sensor will do). Now lets have a zoom lens and make the whole thing high-performingly fast. Of course this is no real problem in Canon dslr format, you just swap out the pancake wide and slot in the 70-200mm f2.8 IS when you need it. (No sweat). But those that like portable little cameras that can take a variety of lenses - such as the GXR for instance - are hugely risk-adversive to great big lenses out front, they are even know to titter a bit when one is actually waved about.
So amidst this great need for smaller more powerful cameras and wishing away the need for physics the smart guys back at camera-design HQ first invent sensor cropping zoom, then polish up their wide angle lens correction algorythms. Couple this with a larger sensor with a high megapixel population and you get every chance that even a cropped image off the sensor will give a very "clear zoom" and if they have the lens correction right then the wide shots will look good as well.
Obviously take this lens out of its comfortable element in a RX100 and plug it into a (say) NEX7 with a suitable mount then there would be something missing.
As they say - "it takes a team of parts to tango".
Therefore I am looking into what may come of this lens-development. The lens in the RX100 might only be useful as a device intimately coupled to sensor and controller chip.
"Ok"we say -there will always be "regular" lenses that can be swapped. Granted. But if the high performance - small size becomes the new-u of cameras then wherefore now? Do they just turn out a swag of different cameras each with a sensor buried in it teamed up to a different type lens or alternatively go the Ricoh-style way? Maybe "one size fits all?"
Of course I am not busting myself for a GRD size camera with aps-c sensor and zoom. But the RX100 seems to be saying that there is a way for those that need such a thing.
I am not plugging it, wanting it, just noting that it might happen. Also it is obvious that there are plenty of arguments saying that it cannot, or need not happen. So there is plenty of room for contrary opinions.
Now I must go off and read about this RX100 thingie ...
Tom Caldwell
... and I am not clamoring either, just wondering if Sony has achieved it's object by a means that we might see more and more of in the future. :)
The interesting point to me is merely that the seemingly dead-end of a sensor/lens module might actually be a glimpse of the future. (Whilst we all moan that we have to change sensor when we change lenses). Not sure of exactly how it might work and I bow gracefully to those that are better informed and more knowledgeable.
To me the biggest "if" is if ever this type of lens becomes seriously usable then can it be used to improve good lenses to make them perform at the highest standard level? Hardly I think as correcting abberations is one thing, getting the lens surfaces and coatings precisely right is another.
Documensony
Tom Caldwell
Tom Caldwell
I still dont get it. Sony has done nothing new here that hasnt been done many times before. Why you think this is new is still unexplained.
Yes. I don't say this to be mean, but it seems to be to an unhealthy level. There's also a lot of rationalizing going on to defend a system that most people feel is broken, at least as far as making economical sense to purchase. I sincerely suggest using all the energy spent on evangelizing an inanimate consumer product on something joyful and/or productive, like taking photos. ;)
The GXR with M module=fantastic. Lensors, no thanks. You have to bend over backwards to fit the square peg in a round hole.
Tom Caldwell
I'm baffled as well. All this energy spent on something that's been around for years. There's been software correction for lenses in P&S and interchangeable cameras alike for years now. Whether it's in the .jpeg engine or Raw software, etc...what's the big deal? This new Sony offers NOTHING unusual in that regard. The big deal about it is the much larger than typical sensor for a P&S that still manages to be pocketable and smaller than it's competition with smaller sensors. That's something to write about.
How can you scale back the M9? It already has no features apart from taking pictures. Less megapixels? Smaller sensor? That's about it.
That remains to be seen. Rumor says FF, but nothing seems to be confirmed.
I remember, however, Leica CEO Kaufmann giving an interview signalling that a true but more compact Leica was in the wings. Something in the tradition of the Leica CL from 1973
I'm no Leica expert, but I have often read that the CL doesn't have all of the normal framelines. I'd require a camera with all of them: 28, 35, 50, 75 and 90mm. I've already got a 35, 50 and 75mm lens, and at some point, they'll be joined by (probably) the Zeiss 28mm f/2.8 and Leica 90mm f/2.5.
Personally, I would think there's considerable opportunity for making a good camera much smaller than M8 - M9 - M10.
And why should Leica sit back and let Fujifilm cash in on a steady stream of Leica'ish cameras. Why not cashing in themselves on all those photographers and enthusiasts who'd love to have a Leica - but who do not have the funds for a M9/10?
Quite right. It's not that I'm dying to have a Leica (I'd rather have a Zeiss-branded camera, if I had the choice... yes, I'm a contrarian :P), but I'd love a camera with which I wouldn't have to use a grey-mode focus peaking and/or zoom to focus correctly. I'd like a camera that shows me something like Ricoh's MODE1 or the NEX's focus peaking, but more accurate. Or another way of focussing when seeing the full image.
I'll just wait and see what the different companies will do. Fuji has an EX-1 in the works, it seems. If they put a normal sensor in, instead one of their own weird designs that need a year or more to be properly supported by the big programs such as Lightroom, then it might be worth to take a look at. The X-1 Pro with M-lenses falls (far) short of my expectations to be honest.
A full-frame camera does not need to be that expensive anymore; a module doesn't need to cost $2000 on it's own. The body and viewfinder each cost around $300 or so. If they only have a module, then I'd not pay more than $1200 or so for one.
To be honest: if Zeiss or Leica would put a Digital Ikon or EM10 (EVIL M) on the market for under $2000, then I'd probably jump ship too, as soon as I can spare the money.
Zeiss or Leica simply cannot do it for the money and it is very unlikely that they ever will. Leica rebadges Panasonics - will that do?
Yes, of course. I've ceased to bother about brands quite a long time ago. The only reason for me to prefer Zeiss over Leica are (imho) the price/performance ratio, and I actually like the slightly warmer yellowish out-of-camera look of the Zeiss lenses over the cooler and blueish look of Leica lenses.
I am surprised that the Leica/Zeiss lobby have not started to refute electronic adjustment even now. But I suppose that this high quality glass has yet to be threatened. Meanwhile such exclusive lens manufacturers as Canon and Nikon must increasingly use electronic enhancement as a matter of course and hardly mention it. Certainly it does not get trumpeted by "EEI" (Electronically Enhanced Image) stickers on their lenses. (grin)
Electronically corrected lenses will remain a feature for budget camera's and lenes for the forseeable future. In the end, nothing beats a good lens. Correcting an image after taking it will, in the end, always be less good than taking it perfectly to begin with. It's just like exposure. You can do a lot in RAW, but you can do more if you start out with a correctly exposed image.
This is most likely. Many lenses in the m43-system are electronically corrected, and t works just like you describe.
For example:
http://www.photozone.de/olympus--four-thirds-lens-tests/468-oly_17_28?start=1
(Move your mouse over the distortion grid to see the uncorrected version.)
Leica only started including all those "normal" framelines with the M4-P and M6 models in the late 1970s/early 1980s. The CL body was released in 1973 and was designed as a compact system with dedicated 40 and 90 mm lenses, it presents 40, 50 and 90 mm framelines. A 28mm lens was later added, most use it with an clip-on viewfinder for framing (coupled focusing through the built in viewfinder).
I have owned many Leica RF cameras since 1969. Never found the 28mm framelines in the M4-P, M6TTL and M9 to be much use, and the 135mm framelines are somewhat small and hard to frame accurately with as well without an eyepiece magnifier.
Godfrey
This new Sony offers [a] much larger than typical sensor for a P&S that still manages to be pocketable and smaller than it's competition with smaller sensors. That's something to write about.
Many people like that ... I think what Tom is wishing for is a GXR module to do the same or even better?
Documensony
it is new, because it just occurred to him. So when it is new to the headmaster of Ricoh forum(s) people feel obliged to engage...
And also it is his speciality to conceptualize and editorialize simple ideas in complicated manner which generates even more garbage and takes away what is left of this brain dead / gear craving forum.....
He just admitted a while ago...fanboys are lost and confused when there is no new gear...so let's write 5000 word empty essays for passtime....
Blah blah blah blah
