musicshootr
Forum Enthusiast
- Messages
- 388
- Reaction score
- 494
I promise I'm not starting this thread to start arguments about equivalency, I just really want to understand something.
First of all, are the below assumptions correct?
Larger sensors can gather more light, and large pixels on that large sensor (i.e. 24mp FF cameras) have the greatest low-light performance.
Large full frame lenses passing light through large mounts are efficient from a light transmission perspective, allegedly leading to greater low light performance in instances like Nikon's Z mount.
High-megapixel sensors take a bit of a hit when it comes to low light performance, and the effect is more pronounced the smaller the sensor is (i.e. the move from 24 to 40 mp on APSC is going to introduce noise, where you can get a clean image at 40mp on FF and only have a noise penalty moving up to, say, 60mp?)
If the above is true, then talk me through something.
Fujifilm is instituting digital cropping on their 40mp APSC sensors to give the user more available focal lengths. When you crop in on that high-mp-count APSC sensor, are you getting the light-gathering capability of APSC just digitally cropped in, or does the light gathering take a hit because you're reading out a smaller portion of the sensor?
On the GFX100RF, if you use it in FF 35mm crop mode, do you get better light gathering performance than putting a 35mm lens on a FF camera (assuming equal aperture on the lens) because the overall sensor is better, or is that 35mm FF mode equivalent to putting a 35mm lens on an equivalent megapixel count, equivalent aperture FF system?
Do Sony FF cameras that have an APSC crop mode perform better in low light in that mode than Sony APSC cameras using the same lens at the same aperture?
Are FF cameras giving up some of the low light and optical benefits of the FF format by opting for higher megapixel sensor designs so folks can crop in to smaller sensor areas?
I am just sort of hazy on whether you incur the penalties of a smaller sensor format by cropping into that sensor area on a larger overall sensor and system.
Thank you in advance for your replies.
