PaulRivers
I am dead set, a priori, against adding anything else of any size to my pockets, hahahaha. I'm already bordering on "is that a camera in your pocket, or are you just happy to see me? " with the amount of stuff in my pocket as it is! :-DI can see from the nature of these excuses that you are dead set, a priori, against using a gray card.![]()
And for the vast majority of my photography, it is simply not possible to carry anything in any other way. I can't carry anything else while social dancing, it just doesn't work. Or while biking...I already carry enough stuff as it is I'm starting to feel like I'm spending more time preparing to go biking than I am actually biking...
Thanks...though since there's a keychain sized version -As I said in my earlier post, I like the WhiBal gray card.I am slightly confused about which card you mean
http://www.amazon.com/GENUINE-WhiBal-Certified-Neutral-Balance/dp/tags-on-product/B000ARHJPW
or
http://www.bhphotovideo.com/c/product/716944-REG/WhiBal_WB7_PK_White_Balance_G7_Pocket.html
http://mtapesdesign.com/whibal/
I think that might actually be small enough for me, could fit in the change pocket in my jeans...
Ok, it's $20 so I just ordered it, enough screwing around, lol.
I hope it turns out to actually be grey, as I didn't have very good luck previously doing the same thing with a white sheet of paper...gray objects seemed to work much better.
I didn't mean the gray card, I meant the color chart thingy that you linked to earlier with like 24 colors on it or something...you know, this one -I'm not sure what you mean: pictures of the card? pictures using the card. I have many images of the card, which were taken during the target shooting process. I do not use that card in my shots; I use the WhiBal gray card for this purpose.I assume from the other thread you linked to on the best way to use the expanded color chart that you've used one - you wouldn't happen to have any sample pictures from that would you?
