You should always use the highest quality setting, unless you have no other option, like out of memory. That's what I think at least. Maybe you won't be able to see any difference in a high compressed image with a low compressed image. But if you look closely you will see the difference. For example, if you look closely at that picture (679 kB) you will see some "squares" that are a result of compression. By using a lower compression setting these squares will not be so easy to spot, which means better quality. But then again, if you don't see the difference then you can of course use whatever setting you like. But in my case I will always try to save my images as a raw file (uncompressed) (haven't bought a digital camera yet, but I have my eyes on the S9500 (S9000)).
Sorry for my English, but it's not my main language.
Regards, Mattias
Regards, Mattias
Does that mean that aving the images in-camera at the lowest
compression (largest file size) is a waste of memory?
