My local pharmacy often has very good deals on large prints, poster prints, etc. I think they would make great gifts or an inexpensive way to see a photo printed at a large size. The pharmacy isn't in my tiny town and I would submit the files via e-mail.
Starting with an NEF file from my Z 7II, what would you recommend be submitted in regards to preferred file type, file size (actual pixel dimensions?) and, if submitted as a JPEG or TIFF, the resolution in dpi? (I use Nikon's NX Studio for PP.)
Is there a simple formula, or would it be dependent on print size?
Thanks for sharing your knowledge!
Bob
I would talk to the pharmacy and see what formats they'll accept. I would think most should be able to accept the most common types (JPEG and TIFF). I'd say TIFF is preferable if it's an option as it's not compressed like a JPEG is.
The whole resolution / DPI thing depends on size and viewing distance, but I'd use 300 dpi as a good (average and widely accepted) number for standard viewing distance (12-18 inches I think). This is at least how I figure out what resolutions I need to use to print at home. I start with the desired print size (in inches) and since most of my images are viewed from 18 inches or closer, I go with 300 dpi. Then I do the math so for an 8x10 print, I will need about 3000 x 2400 (long x short) or 7.2MP. Sometimes I'll just let Photoshop or the Canon Printer add-in (for PS) do the math for me as I just specify a print size and the add-in does most of the other work (determining resolution and downsizing if needed, etc).
But talk to the lab as they may have specific instructions. I guess if you want to error on the "safe" side, send them a larger file than is needed. So if you're not sure what size you want specifically, maybe send them a full-res TIFF file. They should be able to resize it to the desired print size. If not, they'll let you know what size they need and you can do it.
I know at least when I had some of my photos published in magazines, they would tell me to send a certain file size (usually a bit larger than the target page size) and to send it in TIFF format so they could adjust it if needed. Some asked for JPEgs, some asked for TIFFS. But start with the lab first... talk to them.
A note about TIFFS... my personal preference was to always send uncompressed TIFFS (not ones that were compressed using ZIP OR LZW, but rather without any compression -- it's lossless compression by the way so you don't lose any image quality, it just helps keep the file smaller). But i would do this to ensure maximum compatibility but it did result in larger files in some cases. I also tried to leave all layers in-tact or I would create a new merged layer that had all of the changes in a single layer, but this way it would still maintain all layers in case they were needed for some reason, but this last part you could just skip and flatten the file if you wanted to to save space if you decide / need to use TIFF.
* PLEASE NOTE: I generally unsubscribe from forums/comments after a period of time has passed, so if I do not respond, that is likely the reason. *
