R50: Dial default to Aperture in manual movie mode
PowerMike G5
Well-known member
Hoping someone can answer this for me. I'm looking at getting a R50 for casual travel.
One thing that I'm so used to on Canon cameras is that the front dial usually defaults to adjusting aperture first when I'm in video mode. I noticed that the R50 defaults to adjusting shutter speed first instead in this instance, like in the pic attached.
Is there a way to change this in manual movie mode where once you switch to it, the dial is set to change aperture first? Or is this set and I need to retrain my muscle memory?
I never use video, and I have R10, not R50, but I would have thought that there was an option to customise the dials for video in the custom menu (in the same way that it can be done for stills) ?
I only see in the manual that it can customize the lens ring on RF lenses. Unless I'm missing something here.
Not sure about R50, but in R10 manual, it is under "Customise Dials" (pg. 835 - near the back of the manual) under "Custom Functions/MyMenu, Custom Function Setting Items, C.Fn3, Customise Dials", and in camera it is under the custom function menu, tab 3, Customise Dials (just under customise buttons), and you have the option of changing the front dial, rear dial, and control ring dial.
The front dial is defaulted to Shutter speed, but can be set for Aperture (only those 2 options), and same with rear dial (except it has a few other options), and control ring can be set for a multitude of functions including aperture or shutter speed.
Then you can also change the direction of movement for each dial (increase or decrease the aperture or shutter speed for CW or CCW).
I looked thru the menus and don’t see a customization for it.
Hitting the top button on the d-pad changes the focus to aperture, which sticks until the camera turns off.
Or you can set the control ring to adjust aperture, which works in movie mode.
Oh dear - sorry. I had assumed that R50 would retain at least some of this from R10, but obviously not. There really is a lot of little things (that don't feature in the spec sheets or even reviews) that R50 misses out on compared to R10.
I think it's because the R50 only has one dial, so it doesn't allow for customization like the R10.
Thanks for chiming in everyone. It feels like I have to retain muscle memory for this camera, which is a bummer. Having an M6 Mark II, I guess I'm a little used to the multiple dials. I guess there still really isn't anything in Canon's sphere that has the combination of small size and functionailty.
That was the minor inconvenience I have with my R6II and R7. I had to map Aperture to the lens ring on the R7. I don’t adjust Aperture as much on the R7 but I’ve never been a big fan of it.
I guess R50 to R10 is like the M50 was compared to M5 & M6 (& M6 ii) - a seriously throttled back version with limited dials, buttons and functionality (without digging into menus). But it cheaper, and probably many people who have never used a camera with multiple dials, custom modes, self cleaning sensors etc etc don't miss those features.
The R50 is a wonderful camera - I love how light and small it is compared to my R5II, and is able to use the wide range of RF (and EF) lenses. The recent third party RF-S lenses have also made the R50 into a better camera; for me it has pretty much replaced the M6II.
However, it is a little annoying that Canon put what seems to be artificial software limitations in the R50, beyond just the physical such fewer dials, no IBIS, and no sensor cleaning. I wrote examples of it my review , and since then ran into a bunch more (most recent the one the OP pointed out, inability to customize the dial):
  • You cannot change the ISO increment value, it's fixed at ⅓ stop. So it takes three clicks to go from 100 to 200 ISO. I prefer 1 stop increments. (And frankly I am surprised in absence of a control for this, Canon set the value to ⅓ rather than a more user-friendly 1.)
  • Another setting you can’t change is what the magnify button does when viewing an image; I usually change that to zoom to 100% directly so I can check focus. On the R50 the magnify button just incrementally zooms in. I'm not sure how many clicks it takes to get to actual pixels.
  • When taking 3-shot HDR photos, R50 does not save the individual RAW images. While a beginner user would be content with the single combined JPEG, a more advanced user who has gone out of their way to set their default format to RAW would probably enjoy and expect the RAWs in addition to the JPEG.
The above three are small things that I have enjoyed in my recent Canon cameras, and are things I assumed would be there on the R50 as well. It’s a bit disappointing that Canon decided these features (and likely some other things that I haven’t yet noticed) were not appropriate for the R50. While not including some features does simplify the user interface some, it’s not like these make a big difference - the R50’s menus and settings are not appreciably simpler than the R5, and neither is the user manual.
At least the lack of rear dial is something obvious that many/most will notice. I think the "hidden" shortcomings are what diminishes the R50 value - for me at least, and why I opted for R10.
- No sensor cleaning
- No C1 & C2 mode settings
- No Fv mode setting (that I can see)
- No AF-On button
- No M-Fn button
- Quite limited customisation of buttons & dials
- Less AEB options
- No intervalometer
- No mechanical shutter
- Reduced speedlight native compatibility (without adapter)
- Much smaller buffer size (and the R10 doesn't have a large buffer to start with).
- 6 custom functions (vs 18 for R10)
- No remote control terminal
- No UHS-II card support (which further amplifies the smaller buffer issue)
And some other things like the ones you mention - and possibly several more things that I have no noticed (not owning a R50). Most of these things are not apparent to even an experienced Canon user who just picks up the camera in a shop (without trolling through the menus). Most of these things would directly affect my day-to-day use of the camera (the remote terminal & AEB excepted) - this made R50 a non-starter for me.
And IMO the size & weight savings (vs R10) are quite minimal - the single biggest difference is the smaller depth because R50 has a much shallower grip. The 54g weight difference is all but insignificant in my book. IMO R10 is a FAR more useful camera than R50 (at minimal size & weight penalty) - unless the user is aiming for fairly basic "happy snap" usage (which is probably exactly what is aimed at as a target market).
- No AF-On button
- No M-Fn button
- Less AEB options
- No intervalometer
Yup, a lot of limitations. Of course most important for a camera are the image quality and overall performance; and the R50 does a great job, at least for me. So the reduction in weight and size were important enough to prefer the R50 as the replacement for the M6II. Price is also a factor of course.
My biggest wishes would be sensor cleaning, and higher resolution. And of course even smaller/lighter.
Thanks. These extra differences pointed out are actually really helpful.
It's actually making me think about whether I should just stick with my M6 Mark II. The smaller size is ideal as travel is the priority for this camera.
I'm so used to all the extra controls on that body that are lost on the R50. And the smaller lenses really contribute here as well.
It seems like I generally lose a bit on image quality going to the 24mpx APS-C Canon R models as well. High ISO looks better on the M6 Mark II than the R50. It seems like it further gets worse too comparing the kit lenses with the f/3.5 vs f/4.5 starting points, let alone the 22mm f/2 not having a RF-S equivalent.
The only thing I really like on the R bodies is the integrated EVF. I really wish that was the case on the M6 Mark II.
As mentioned, there are probably even more that I have mentioned.
I think that many people over state the "size difference" between, say, M6 ii and R10. The single biggest difference in dimensions is the depth (front to back), and most of that difference is due to the deeper grip on R10. Noting that this depth is measured without a lens, this means that practically, most of the difference disappears once you fit a lens bigger than a EF-M 22mm.
M6 ii - 120 x 70 x 49mm & 361g
R10 - 122 x 88 x 83 & 429g
R50 - 116 x 86 x 69 & 375g
So, the EVF hump on R10 makes it 18mm taller than M6 ii, but if the optional add-on EVF is used, M6 ii is taller. In real practical terms, this small 18mm difference is only going to be noticed if you are trying to jam the camera (with a tiny lens) into a coat pocket (or ladies handbag). Almost any carried camera bag will be the same size for either camera.
R10 is 34mm deeper, which is significant, but as mentioned most of this is due to the grip, and even with the basic zoom kit lenses fitted to either camera, the grip depth difference effectively disappears (because the lens sticks out further than the grip. Again, it would make a difference if the camera was to be jammed into a coat pocket with a tiny lens, but the space in a bag that they would take up is almost the same.
R10 is 68g heavier than M6 ii, which is probably enough for many to notice the difference if they were comparing side by side. But in reality for day to day use, the 68g really isn't noticeable (unless you have it in your pocket).
And R50 compared to R10 is an even smaller difference. IMO the ONLY reason to buy R50 would be a restricted budget, or a high degree of certainty that the additional features listed above for R10 would never be used. I think that the long list of differences are probably missed by most R50 buyers because I think that there are certainly some quite serious omissions for anyone serious about photography or wanting to grow into the camera/system.
As regards the differences between M6 ii and R10, I think that R10 outperforms it is most respects including AF, tracking, subject detection, frame rate, responsiveness, and several other features found in Digic X. The M6 ii has a few things that some value - size & weight (assuming you don't use extra EVF or larger lenses - if you use larger lenses the compactness benefit disappears and at some point the small size & grip becomes a disadvantage), 32Mp has more room for cropping than 24Mp, and for a small minority who prefer the tilt LCD to the flippy LCD. Otherwise I think that R10 is a better and more rounded camera, and significantly better than R50.
Agreed. As mentione dabove, for anyone using M6 ii almost exclusively with small primes like 22mm, the M6 ii certainly wins on compactness. Once the primes get a bit (and not much) bigger, even Sigma 32mm size, the compactness of the body all but vanishes. The RF-S 18-150 is essentially exactly the same dimensions as EF-M 18-150 except for the larger mount ring, and with these lenses mounted respectively, the differences in size & weight is negligible.
I don't think so. The new 24Mp sensor is pretty good. You do lose some ability to crop (about 15%) but that is all.
Again, I am not so sure.
I have started using DxO to process RAW images, and between it and the 24Mp sensors of both R10 & R8, I am seriously impressed with the abilities at higher ISO. I usually have my RF 100-400 mounted on R10, and often at 400mm which is f8 with up to ISO 6400 and getting quite clean images.
Here is an example of the same image just converted in DxO and with it processed in DxO with lens corrections & Deep prime NR turned on.
Best to view Original size and zoom in, especially on the less detailed areas where the noise difference is quite pronounced.
So the point is that I have not found the slower lens nearly as big a drawback as I though it might be. I kept my excellent EF 100-400L ii and bought an adapter, but I have never actually used it since getting the RF 100-400. Lugging the extra 1.2kg around is a far bigger downside than shooting at 1 stop faster ISO.
Effectively out of camera
Same as above with corrections and NR turned on.
I would imagine that several third party makers are working on a range of RF-S lenses, as they did with EF-S and EF-M, so while Canon might not have anything, I am sure that others will be forthcoming.
I ditched my first M body (M3) because of the lack of EVF - I need glasses to read but not for anything else, so having to keep taking glasses on and off was painful. I also live in (sunny) Australia where using the LCD outdoors can be difficult.
A small correction here - the above numbers for the R10 and R50 are with batteries; the M6II with batteries is 408g, so actually heavier than the R50.
Well there you go, even closer than I thought. I was just using the numbers off TDP.
Yes, its largely the 22mm f/2 that keep me with the system. There isn't anything like this with the RF-S lenses yet. In terms of small size, focal length and large aperture.
https://www.dpreview.com/reviews/im...tr16_3=32&normalization=full&widget=1&x=0&y=0
When I look at the RAW files comparison, the noise looks better at ISO 6400 on the M6 Mark II vs R10. There seems to be a bit more overall noise and larger chroma noise throughout on the R10. When you downsize the M6 Mark II's image to match in size, it gets even better. But to your point below...
I've been using the latest DXO to process the raws from the M6 Mark II for a while and it's amazing. I'd imagine this workflow for both cameras will largely wipe the differences between the cameras at 6400 ISO and above and normalize them.
Thanks for sharing your thoughts!
Perhaps a R8 + RF 28mm - bigger but not hugely so, and focal length not terribly different.
Or, even R10 + RF 28 - bigger (mostly due to rear protrusion of EVF) and slightly longer FL.
This also illustrates my point about the deeper grips - even with the tiny RF28, the lens sticks out further than the R10 or R8 grips.
