R5 recording limits temp/sensor correlations (continued)
I've created a web-based javascript app that lets you quickly set the camera's clock to +1 day and -1 day to help automate visionrouge's workaround. It only works in browsers that allow you to disable CORS Policy Security. Unfortunately none of the mobile web browsers available support that option, so for now this is limited to home/office/studio use.
Here is the link to the app: http://www.testcams.com/ccapi/datehack.html
Full instructions including how to disable CORS Policy security are in the GitHub repository.
It was around 70.
It was around 70.
That is good to know. Thank you. So I probably do not need to buy a Ninja V unless I plan to shoot long videos in 4KHQ long videos in 4K60 for YouTube or Vimeo distribution. Video does not accept 8K the last time I checked but 4K is acceptible.
I had never worried about this because the still performance with 45MP AFII is what I need formy serious work and the rest is not critical. Most of my video use is 2K30 UHD with zero use of any 60 or 120 modes.
So much for the conspiracy theories. You don't want to cook your electronics. Its how you do accelerated life testing...
Yes, when I looked at this chart late last night, and no subsequent posters had yet replied, I thought it quite odd that the chart didn't generate an immediate response that a supposed "workaround" like this would likely fry the R5's electronics in a fairly quick manner. These internal temperatures are well above ones that would ordinarily prompt any manufacturer to set limits on operation, whether through heat sensors or timers. You may argue that the design should have allowed better cooling and faster temperature cool downs, but that would have required any or all of a lot of less than ideal changes: more space for heat sinks and fans in a bigger body, possible noise and vibration problems and poorer weather sealing, or limitations on bit depth, and ommision of specifications which are uniquely high in the case of the R5. But the main take-away here should be: given the reality of what the R5 actually is, rather than what some people had wished it to be, that Canon is trying to protect buyers, not trick them.
If the temperatures reached were dangerous enough to fry the R5's electronics, then no workaround should have been possible.
Hahaha!! Sorry this if funny. It isn’t canon’s fault that people start messing around with the camera as they have.
You shouldn’t be able to mess with a electric saw and remove the safety mechanisms built in, but by just removing a few screws you can. It isn’t the manufacturer’s responsibility to make things completely idiot proof.
Since canon probably didn’t expect to what extent people will mess with it, it is possible that they do correct this via FW down the road. Hard temp sensor thresholds and problem solved. But then I am sure people will complain about that too.
You ignored the subsequent section. They have temperature based shut off also, so if the temperatures being discussed really are enough to fry electronics, that should cut in and shut off immediately.
I'm simply disputing that temperatures ever reached electronics frying levels with the limits that have been worked around. Rather the levels are likely quite conservative if they are relying on timers, and so far no camera had been fried yet bypassing the timers.
you understand very little of this subject.
On the contrary, I understand this subject probably more than a lot of people here.
you're certainly not showing it.
1) it's not a matter of "frying" it's a reduction of lifespan with increased heat. Some things are more susceptible to heat than others.
You like lawny13 failed to read the discussion and are going off on a completely different subject (lifespan reduction vs frying the electronics). As I bolded above, the entire discussion was talking about dangerous temperatures that require immediate shut down.
actually what you are discussing is a strawman and not relevant.
Well two separate people brought it upthread (it was not brought up by me) and if it were true then it would make a huge difference in whether people should be trying this workaround or not. So it's definitely relevant to the discussion and in fact in this subthread, it's all we are discussing (you were the one trying to change the subject to be about service life).
All I am disputing is the notion that the workaround is bypassing sensing of dangerous temperatures. Rather if the temperature reaches dangerous levels the camera will shut down immediately based on temperature. No workaround should be able to bypass this. As such the current workaround, won't result in the frying your camera in short order (as demonstrated by multiple people who tried already). Whether it reduces average service life is a different subject.
actually it's not.
there's always a level of temperature when electronics decide that's it. time to cool off.
that could be because of reduced performance, reliability or even things such as occupational hazards. Some things inside of a camera are significantly sensitive to temperature.
it's hardly ever because things are about to burst into flames.
The thermal shutdown is not about literally bursting in flames but about component failure (temporary or permanent) in a short period of time (within seconds to hours at most). Back in the days before auto throttling and shutdown was common on boards/CPUs, people have burned out their CPUs in seconds due to a missing heatsink or improperly mounted one. With a heatsink (but fan failure) it is less likely to fry the CPU, but the system will still crash in minutes. You can see plenty of cases of this in the Athlon forums in particular (Intel had built in thermal protection earlier). With thermal based throttling and shutdown this is all prevented.
I mean Sony has shutdowns as well (without warning) because that because it was seconds away from bursting into flames?
Sony actually allows you to toggle this with the "Auto Pwr OFF Temp." It can shut down on a more conservative temp (perhaps service life related), but it can also shut down at a higher temp that is more dangerous for the camera (or user). There's debate about whether this temperature is about temperatures that might burn a person holding the camera, vs the traditional processor junction temperature limits (as above). In either case it allows significantly longer recording times before shutdown.
Also we don't know what envelope and assumptions Canon is operating under.
So without knowing those assumptions, you can't factually state anything.
what we do know is that "flipping the clock" does "something" .. whether or not it effectively works around a design limitation that Canon has isolated and is concerned about - no one knows, but it certainly does not have to be because the damned camera is about to smolder.
I'm not saying it's because the camera is about to smolder. In fact I'm saying the opposite, that the limits being removed by this workaround are likely more conservative ones that would not result in immediate failure of the camera after removal (whether permanent damage or camera crashing). It was the two people I was responding to that was suggesting that this workaround would cook or fry the camera.
What I find interesting is that many people are making assumptions without knowing all the facts, and none of us know the facts. Not you, Not me. Certainly not Andrew from EOSHD, no one outside of Canon knows the design criteria.
Sure, but it's at least been demonstrated you won't fry your camera by removing the timer part of the limits (which for most people are the ones they want removed the most). I don't think people have issue with keeping the temperature based shutdown (people aren't working on hacks to bypass those). As for whether it might reduce service life, that is another discussion completely (which you yourself say you don't have evidence to support either way, so there are no conclusions that can be reached anyways).
Regardless of how you want to phase it. Mess around with the camera at your own risk. You will likely void the warrantee, simple as that. If people want to do such a thing with their $4000 camera, then they do so at their own risk.
Lensrentals has a very thorough tear down of the R5 now. Really doesn’t look like canon was messing around. Not much space in there for convection and. It much places of the heat to go (very well weather sealed) and canon did the thermal pathways a bit more extensive than most manufacturers.
So... just keep in mind that the cameras tend to have error logs (like a little black box) that recorders issues that might occur. If for some reason it can see events of sudden power outages, or change of the internal clock canon may very well be able to determine the “work around a used”. If your camera dies between the short term or the long term and you have been doing this... well warrantee may be void. And I don’t care how people want to “justify” this tinkering. The majority do not even need 8k.
Try using your own opinion and experience, otherwise people may laugh at you.
I would but I'm not expert in color grading, visual acuity, perception of videos, etc. I'm afraid if I say, "Huhm.. that looks good to me, boss".. without solid examples, proof, or references, I maybe the one that comes of as a fool; people might laugh at me. Better to use other people's opinion and experiences who are professionals. It's their reputation on the line, not mime.
How about the choice of not giving an opinion when you do not know what you are talking about? Seriously, why comment on a subject you have no personal experience with? Like other folks want to know yours or anybody else's "opinion facts"?
And how do you know weather or not I am a video professional?
This is not a conversation as you have your hands over your ears and are saying the same thing over and over while evidence is given to the contrary. If this topic was about uncompressed RAW video I could see the opinion that the spec is overindulgent, but 10bit? No.
Signing off this thread. Happy to discuss, help and inform, but not to talk past (which will eventually becoming shouting...) No worries.
Bassman
I agree with you that 10bit video is a advance over 8bit video with little downside other than cost. High end video cameras a systems offer 10bits. It is more expensive to do this and that is only concern I know of. The market will decide how many buyers will pay up for the feature. Sure many 8,12,14 & 16 bit video alternatives appear in some parts of some camera and the lowest 8 bits are alway going expensive to obtain yet some buyers will want them. How important for this or that is up to the invidual buyers and the outcomes they are trying to achieve. Great image can be made with 8bits but that is not really the question. The question is how bits can you provide in a system and what all the cost and benefits are of doing so. Clearly the 10bit offer makes sense to Canon and Sony to sell cameras and some customer will demand it. The the extra bits on only a very and in demanding situations some people care. You right it believing adding 10bits to this product is an important addition IMO.
My understanding is that the HLG video standard for HDR is a 10 bit standard. HDR displays won't even recognize it as HDR content if it isn't in 10 bit. This is actually one of the problems with Gen 3 Sony cameras which only give you HLG in 8 bit so the video can only be viewed properly as HDR content on a Sony display. If the standards require 10 bit, I'd say the discussion of 8 vs 10 bit is basically a moot point. 10 bit is the new minimum for certain kinds of content.
Ted
http://www.flickr.com/photos/tedchang/
C&C is encouraged, I'm always learning
actually it's not.
Again, a different scenario than a camera. And you're missing the point, you went off on the fact that if it's shutting down quickly to prevent frying. it doesn't have to be because if's to the point of "frying".
CMOS sensors are very sensitive to heat.
Cameras are held (tightly) for long periods of time.
You cut out my response again. Not what I said at all. I'm saying the exact opposite. It was the two people (David Franklin and gavin) I responded to originally that was claiming that this workaround to remove the timer would fry the camera. What you are saying above is agreeing with my original argument against them. Maybe you are confusing me with them.
What I'm saying is that if temperatures ever reached near the point of frying the camera, there would be another separate thermal shutdown that would prevent that. From recent interviews they have 3 thermal sensors that allow them to monitor temperatures.
Here's the response you cut out:
Sure, that is a fair take, but I was simply disputing that this workaround would go to the point of frying your camera in short order as the two people claimed. We know from Gordon Laing's video the camera has 3 temperature sensors that Canon monitors, so they would be able to prevent that from happening regardless of how you work around their timer.
https://www.dpreview.com/forums/post/64302189
Of course there might be longer term implications (like your camera lasting half the time it might have), but that's a different subject.
I agree, there must be a kill switch that prevent the camera from smoking up and turning into the Samsung Galaxy Note 7...
actually it's not.
Ah. You are right. Too much sun in Thailand causing reading incomprehension ;)
My apologies.
and yes you're right, it's not going to cause it to go nuclear, but it will most likely reduce the lifespan or cause some other unwarranted side effects.
