I really wish camera review sites could include resolution test done using some kind of robot hand or something that will emulate human hand movement/ shake. The same amount of movement will be done for testing different cameras that will emulate "typical" human hand movement at slower shutter speeds (say, 1/15, 1/30 sec etc.). And then we will print the photos at same size, as well as keep printing bigger and bigger from the higher MP body until it has the same perceived resolution per inch (from same viewing distance - more like comparing 100% crops to understand how much cropping advantage the higher MP body has) as the lower MP body.
Yes...and auto review sites should drive Ferraris through dirt roads to see how they cope...
What a perversion...You feel that a better specified product should be taken through tests designed to demonstrate that the areas where it may be better specified can work against
some types of use?...Do you feel menaced by other brands offerings to this illogical extent...?...Good grief...
People really have to stop with this insecurities and put into good use what they've got...in your case, for starters, how about letting us see what your photography is all about, instead of graphics in you DPR galleries.?..You know, photographs are taken to be seen...
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.pbase.com/photokhan
(PBase Supporter)
