Ethan Hansen
PP RGB is the only option Camera Raw offers that fits the bill here. It is what I use for the same reasons - at least when I am working on imager in ACR for which the final output is potentially something that surpasses Adobe RGB. I do most of my image processing using Capture One which allows using any color space for output. I'm partial to Bruce Lindbloom's Beta RGB here. It is smaller than ProPhoto RGB, hence fewer quantization errors appear. It is also large enough to encompass the output of both printers and DSLRs. Finally, it is a gamma 2.2 color space, which is better than PP RGB's 1.8 for B&W work (but that borders on a how many photons can dance on the head of a pixel discussion).Ethan, my workflow is a little different so I'm wondering if you
can offer some insight for me. I'm shooting NEF with a D70 and
using Photoshop Camera RAW to do the conversion. I'm printing with
an i960 using custom profiles. While I realize that ProPhoto RGB
essentially contains all visible color and is overkill, I'm using
it as my working space for a couple of reasons:
1) Both my camera and printer are capable of producing colors
outside of Adobe RGB, and it would seem to me that to get the most
out of this equipment I would want to use a working space that
fully contains the gamut of both devices. ProPhoto RGB seems to be
the only color space that does that (at least, out of the ones
installed on my system).
Bruce certainly is more knowledgeable about ACR than me. Still, something sounds strange here, and not having a copy of his book at hand, I can't check. A strength of ACR is that it carries out most adjustments in the lineary encoded raw output space. Many are performed on the luminance data alone. The internal camera profiles are then used to convert into one of the four output color space selections. I do not see where an intermediate pass through PP RGB would be beneficial. This is a problem with Capture One, which uses a funky "Phase One RGB" space to do all too many adjustments in. If ACR does indeed convert to PP RGB, then you certainly would avoid a second conversion.2) According to Bruce Fraser's Camera RAW book, Photoshop uses
ProPhoto RGB internally during the conversion, so by keeping the
file in that working space I avoid a conversion.
Just checked something: I processed two versions of an image having colors that fell outside the sRGB gamut in ACR. I sent one to sRGB, the other to ProPhoto. Converting the PP RGB version to sRGB afterwards gave an image exactly identical to the sRGB one. This cursory experiment indicates Bruce is right.
All sounds reasonable to me! If, however, you have an image that requires heavy-handed editing, there might well be merit to dropping to Adobe RGB first. This is particularly true for prints on matte papers where the output range is well within aRGB. A color space conversion here will do less damage than the potential for posterization in yellows and browns that can easily happen with large edits in PP RGB.Given those facts does ProPhoto RGB not make sense to use as a
working space? Unlike the orginal poster, I do NOT convert my
images to sRGB at any point. I also do all my editing in 16-bit
mode (even the plug-ins I use regularly support 16-bit now). So
basically my images start out in ProPhoto RGB 16-bit and stay that
way through the entire workflow, until printing when QImage will
use my paper-specific custom printer profile. This approach seems
to be working pretty well for me, but if there are ways to improve
it I'm always open to suggestion.
Ethan Hansen
http://www.drycreekphoto.com/
