Bobo Hodls
The first shot was actually 10/10000s (1/1000s).A keen observation about the corners, I think I'll try yours suggested experiment, just for the heck of it.Well, there are only three alternatives, poor equipment, incorrect technique or optical physics property of the hardware, but I don’t think its any kind of birefringence. I can see that in the second photo the top left and bottom right corners look sharper than the rest of the image. If it was me I would put the camera on a tripod, remove the filter and hold half of it over the lens with my fingers, then rotate it in quarter-turns for four test shots.
Or just buy a new filter.
Bob (and all)
A bit more about the setup for the comparison 'tree' shots: I used a tripod, the camera was in apeture priority mode and OIS was set to the ON position. So in A mode at f5.6, the first tree shot without filter was 10/1000sec, and the second shot with the filter was 10/3200sec..... so addition of the filter is something on the order of losing 1 1/3 stops? Obviously, this old filter is not of suitable quality. Will a typical high(ish) quality polarized filter block the same order of light? or is what I'm seeing just another side effect of the lens quality?
You have not yet determined the filter is inadequate, and most polarizers are expected to hold back about 1.5 stops of light. It may well be, but your technique needs to be verified.
OIS while on a tripod is asking for trouble, try it w/o OIS enabled with and w/o polarizer.
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
