Seumas MacCombie
Forum Enthusiast
Seumas MacCombie
I have diffused with the practice golf balls , the one with the holes, this allows any heat to escape, for a variation I have also used the coloured ones, also I have used the small measuring cup that you find in these protein powers, they fit perfectly over the flash of the 7*7, if you need more diffusing add a wee bit of onion paper or others to the inside of the cup, I usually cut the material the depth and the circumference and place inside the cup then drop it on the flash, adjust the strength o' the flash. the cut out in the practice golf ball, or ping pong are 36 mm on the long side, 22 mm on the short and 15 mm wide or more or less to suit , They all work with different variations Seumas, Och aye there are a thousand things oot there
O' gies the power, the gift tae gie us, tae see oorsel's as ithers see us
