As far as I know, the standard way to change the color of an object is to use a Hue/Saturation adjustment layer with the "Colorize" checkbox . This works well if you can eyeball the color that you want and get the sliders to match.
I have an image and I would like to change a layer to match an exact color that I extract from elsewhere in the image. There's no way to enter an RGB or HSL value using the Hue/Adjustment layer, unfortunately. I would have thought that I could just use the eyedropper to grab a color from the image, the same way that can be done when picking text color or other colors on the layer adjustment panels.
Is there a better way to apply a specific color to a layer without needing to eyeball it with the Hue/Saturation adjustment sliders?
Thanks!
Thanks!
