ON1 2024_Luminar Neo as a plug-in help
p900learner
Mid-West, US
Thanks in advance for your direction. Noticed a YouTube that demoed ON1 and Luminar Neo workflow. Instructions were provided in text form of how to set it up.
lots of questions about how to set up Neo as a plugin in On1. I got the below instructions from On1 directly. If you still cannot get it to work, please contact their support team. Hope this helps and thanks for watching! If you have Photoshop installed, the easiest thing to do it is to set the “Secondary Plugin Folder” location in our preferences to Photoshop’s plugin folder, which is set by default when you press the Choose button. If you don’t have Photoshop installed you need to manually copy the photoshop plugin file from the Luminar application folder into our plugin folder, as their plugin installer does not recognize any third-party plugin hosts and lacks the ability to configure one.
Here are the files and paths: Windows Copy "C:\Program Files\Skylum\Luminar Neo\LuminarNeo.8bf” to C:\Users\your user name\AppData\Roaming\ON1\ON1 Photo RAW 2022\PhotoshopPlugins\
I can see the Plug-ins tab in Preferences of ON1 but don't know what to do with it. Or how to copy the above file paths to where they need to go.
Totally lost and have no idea where to start or what to do.
I should note the Youtube was I believe a 2022 version of ON1. I do not have the ON 1 Max version.
I won't be able to reply promptly to any help today. I can reply this evening.
Appreciate the help.
Ev
