cr3shooter
Active member
Recently I’ve experienced a strange intermittent shutter related fault on my M6 II. Most of my shooting is in bursts on either the H or H+ speed setting. The fault is that in the middle of a burst the camera doesn’t record one or more frames. Sometimes it sounds like the shutter fired perfectly but it didn’t record the frame. Sometimes it works perfectly. Sometimes the skip sounds like the camera was on L speed, which it wasn’t. Every time the first and second frames are recorded and the missing frames are after that without any pattern to what’s missing. Sometimes one frame is skipped. Sometimes it’s multiple frames.
Other items to note:
There’s no error message on the camera.
The battery is freshly charged.
It shows the same fault on a different brand of memory card.
Camera has done about 55,000 frames
Camera has been powered off & on again by removing the battery.
I can’t see any setting that needs changing and it sounds like a trip to the camera scrapyard or Canon Repair Services is needed for a new shutter.
Has anyone else seen this ?
