While NX1 has a solid amount of programmable keys, the NX500 is limited to just few that can perform only a small subset of operations. For example, in order to have a video preview (Movie STBY) you have to assign it to DEL (Custom/Trashcan) button but that means you cannot use a single click to switch to RAW shooting.
This is frustrating.
There are also some other illogical choices like:
Alternatively, just unpack sd.tar from here to the root of SD card and use it in the camera. Then try it out.
Use any of the key combinations, like:
No.
But you can
In scripts directory on SD card there is a bunch of shell scripts called EV_EV.sh, EV_OK.sh, EV_AEL.sh and the like. They are called when corresponding combination of keys is pressed. You can freely alter their contents (you should first test interactively via telnet - it's easier that way). You can also create other files for other key combinations.
Possible key combinations (shell script names) on NX500:
- Having to choose between delay timer AND bracketing is just silly.
- Reseting power zoom lens to 16mm every time the camera powers on ...
- Not being able to quickly switch from AF-S and Single-shot to AF-C and Continuous-H ...
- ... whatever irks you ...
- Go to following address and follow instructions
- EV+HalfPressShutter -> take a shot after roughly 10s (with blinking lights) - any shot including bracketing and burst
- Double click EV (exposure compensation button) -> switch between AF-S/S and AF-C/C-H
- EV+AEL (Press EV - click AEL - release EV) -> switch between SuperFine JPEG and RAW (not RAW+SF)
- EV+OK -> (16-50pz only) zoom to 50mm and iZoom to 2.0x
- EV+MOBILE -> (connect to wireless before clicking this) start telnet server and display IP address for 30s on screen
No.
But you can
- EV_EV.sh - double click EV
- EV_MOBILE.sh
- EV_AEL.sh
- EV_S1.sh - EV + half press the shutter
- EV_S2.sh - EV + full press the shutter
- EV_OK
- EV_UP
- EV_DOWN
- EV_LEFT
- EV_RIGHT
