conceptics
New member
Hi everyone
I am new to this forum, but have been an avid reader for years. Anyway, let me get straight to the point.
I have been a Nikon Z7II shooter for some time (before that d800 for several years). I have now recently extended my collection of Nikon cameras by buying a Nikon Z30 with the 16-50mm kit lens to focus on one very simple use-case: time-lapse, or more specifically, drive-lapse videos for our upcoming trip to the US-westcoast, where we will be doing a lot of driving.
To create drive-lapse, I am using an ND64 filter on the kit lens and using the following settings for a 24fps video:
1.) 12x speed equivalent
Interval: 0.5s, mode: S (Shutter priority), shutter-speed: 1/4s, auto-ISO: enabled, exposure-smoothing: on, silent-photography: on
2.) 24x speed equivalent
Interval: 1.0s, mode: S (Shutter priority), shutter-speed: 1/2s, auto-ISO: enabled, exposure-smoothing: on, silent-photography: on
With these settings, you can achieve smooth motion blur that looks a lot nicer than what your typical GoPro camera can achieve that looks choppy and aesthetically unpleasing. By being in shutter-priority mode, the motion blur remains consistent throughout the recording. Varying lighting conditions are addressed with the variable aperture and auto-ISO.
This works well, however, there is a catch:
Using option 1 and the shortest available interval of 0.5s, the interval isn't consistent under certain circumstances. When the aperture closes beyond f/7.1 with silent-photography enabled (no mechanical shutter), the interval changes to 1.0s. This is an issue, as this ruins the drive-lapse recording, as in extremely bright conditions when the aperture closes to f/8 or beyond, the interval changes to 1.0s and the recording doubles in speed from 12x to 24x for these periods.
This can be tested rather easily by setting up the Nikon on a tripod with the above mentioned settings and pointing a flash light at it while looking at the aperture. When the aperture is close to wide open, the interval of 0.5s is met, however once light hits the lens and the aperture needs to close farther and beyond f/7.1, the interval slows to 1.0s.
There is one solution: Disable silent-photography and thus enable the mechanical shutter. This, for some reason, solves the problem entirely as then, even if the aperture closes beyond f/7.1 (i.e. f/11), the interval of 0.5s is maintained consistently. This unfortunately isn't feasible, as the wear & tear is too high. The mechanical shutter of a Z30 is rated at 150k, which would roughly equal 25 hours of drive lapse.
My observations thus conclude;
For consistent drive-lapse or time-lapses of any kind requiring a consistent shutter-speed and interval, you need to set an interval of at least 1.0s. If you absolutely require 0.5s, you need to have the camera in M-mode and limit the aperture to something wider than f/8 and work entirely with auto-ISO to counter variations in lighting (which to be fair, is probably not possible on a typical drive including varying weather conditions or tunnels). Perhaps using an ND1000 filter or stronger could provide a workable solution, wherein you keep the camera in shutter-priority and push the camera to use an almost wide-open aperture even in extreme bright conditions, however live with the compromise that for the most part, you will be pushing your ISO under normal conditions and beyond once it gets cloudy.
Has anyone made similar observations and/or found other solutions?
Also; does anyone have any idea why, when the aperture closes to f/8 or beyond, that the interval is pushed to 1.0s? One would assume that the aperture isn't fast enough, thus, that is the limiting factor, however when disabling silent photography, the camera is quick enough to engage the aperture within the interval. So what is the reason?
For the record, I have also tested different lenses to see if this behavior is lens-specific, but testing the 35mm f/1.8 on my Z30 revealed that it behaves identical. I have also tested the Z7II and the results are similar to identical.
And most importantly; Anyone know why the aperture changes constantly during such a recording? One would think/hope to reduce wear & tear, the aperture would stay and only adjust when the lighting changes? Is there a reason for this constant opening/closing?
