UncleVanya
I shoot Sony FF (A7RV, A7RIII), Sony APSC (a6600, a6300 infrared), Pentax APSC (KP, K-3),Sony 1" (RX100 IV, and VI), and now m43 (OM-1).
I had dropped m43 a while back just to simplify my sprawl. But my dad's OM-1 is mine now and I can't really give it up. I have the 12-40 Pro 2.8 II and the 40-150 Pro F4 lenses. I have been experimenting with it and I'm still learning.
C1 is setup for mostly static subjects. Mechanical Shutter with Antishock enabled. S-AF, Single Point target. Aperture preferred.
C2 is action oriented. Cross type target, Mechanical continuous shutter, antishock, C-AF + TR, no subject recognition enabled. (I was shooting birds and surfers this weekend, didn't want to try to swap back and forth). Shutter preferred, base 1/1000th.
Lots of people seem to hate C-AF+TR - it's clunky compared to even my a6600 in many ways, but it seems the best option if I want to focus and then recompose but track the subject. Point, acquire, reframe, pan to keep subject in the frame... Am I missing something else that works? I tried C-AF with Large target - but hitting the target is spotty. I tried smaller targets but then it wouldn't stick to it if I recomposed.
The higher speed all electronic blackout free continuous mode was recommended but 50FPS is too much for me to sort through. It makes me crazy and the buffer is really small at that point. I prefer shooting a few frames at a time, sometimes 10-20.
Fully Electronic Shutter was also a consideration for the S-AF mode - is there a big advantage over the Mechanical with anti-shock? My understanding is that this mode uses ECFS but there was some discussion of fully electronic shutter below 1/350th?
I shoot Raw + SF because if I can use SOOC - I will, but I like having the raw for more tinkering if needed/desired.
I am trying to avoid expanding this system too much.. but the 25/1.8 and perhaps a 45/1.8 may be on the horizon at some point. My past m43 gear included a 20/f1.7, a 12-32, a 12-35 vario f4-5.6, a 12-35/2.8, a 17/2.8, a 60/2.8 Macro, a 30/2.8 Sigma, a 45-175, a 42.5/1.7, etc. I don't want to drop down that hole again as I am feeding too many systems already.
This week was an experiment into figuring out how well this works for travel.
Conclusion: It's bigger than the old EM1 or GX8 or GX7 I traveled with. The Pro lenses are quite good. The 40-150f4 Pro is a good long lens but a little shy of what is needed for surfers and birds in many cases but I made it work. Wider and Longer I own already for other systems.
The GX7 or GX8 or EM1 with the 12-32, 35-100 or 45-175, a 20mm prime and maybe the 9mm fisheye body cap - was lighter and smaller and wider range - but the OM-1 has a few tricks that make it nicer in many ways.
