multiple ~ EyE ~ reversed
mark240668
US
All with reversed MF sigma 24mm and homemade diffuser with pop-up flash. You can see and read about my setup here. blog.mdsign.nl (information link on the right) I wanted to make eyecontact with the bugs as if they wonder as much as I do when watching these critters.
cheers, Mark
--+--+--+--+--: http://www.dijstelberge.nl/ :--+--+--+--+--
--+--+--+--+--: http://www.mdsign.nl/fotos/D70 :--+--+--+--+--
--+--+--+--+--: http://blog.mdsign.nl/ :--+--+--+--+--
flash.
Who did the great make-up work on your models? ;-)
Seriously, stunning work. Your earlier posts inspired me to order a used 24mm and a reversing ring which will hopefully arrive next week. I fear it will take a huge amount of time and practice to produce anything that remotely ressembles your fabulous pics. I don't suppose I ever will but you motivated me to try.
My wife and daughter are not pleased; I've explained that it's all your fault and you should be hearing from them soon ;-)
Great macro details Mark!
which sigma 24 lens did you use? will a Nikon 24 works?
I use the MF24mm http://www.photodo.com/product_463.html
Yeah I think the nikon will work as good as the sigma.
24mm reverse is very close to the subjects, impressive to get that
close to take a shoot.
Yes it is close but not extreme close. With the tamron it is 70mm and with the sigma reversed it is 52mm.
cheers, Mark
flash.
I did. ;)
It is not that difficult. Lots of others have done it too. With a little practice on static subject youre of hunting for bugs.
oops. Time to change my name and go under cover. thanks a lot mate. ;)
cheers, Mark
How'd you get so close, and such good focus? I find I have to manually focus at high magnification, and even a little movement (either mine or the bug's) makes a tremendous difference in sharpness.
Great shots!!
Kabe Luna
http://www.flickr.com/photos/kabeluna/
And no tricks whatsoever. Just stalking. I did put some info about this technique on my website.
http://blog.mdsign.nl or http://iloblog.mdsign.nl/blog?Home&category=2
Great shots!!
thanks a lot Kabe.
cheers, Mark
I never done anything like this, so I can only comment - best I have seen.
  • Sergey
shot with perfection in mind and not bugs were hurt or frozen (except in the image) in the process:)
Not crazy about bug macro shots, but these are positively OUT OF THIS WORLD! My goodness - too good to be true. Man O man O man.............
Photography - One of the few things you can still do legally - sort of.
