kkardster
I went to swap memory cards and the new card would only go half-way in before meeting unexpected resistance. I shined a light in the slot and saw something in there. Using a toothpick I was able to remove the foreign body and found it to be the header from the previous memory card.
SD Card with separated header
I’m certain that there are photos on the card that I haven’t had the chance to back up so I’ll want to at least do that.
I’ll likely split the case in two and see if I can reseat the header. If so, I’ll tape the case shut and attempt to to copy the files off before discarding it.
Anybody have any other advice before I try my surgery?
Bruce
You learn something new every time you press the shutter
Bruce
