qianp2k wrote:
SubPrime wrote:
qianp2k wrote:
http://www.dpreview.com/forums/thread/3514784
You got kidding me. How many dual system owners we have heard said virtually no difference when print to 30x20" or even 40x30".
You came up with one name. I am a dual system owner who says you can see noticeable difference when print to 30x20"
You must kidding me that if you print to 20x30" from above Rick's samples, you will see noticeable difference?
I wasn't referring to that example.
There are other comparison which reveal that the D800 renders detail the 5D3 cannot even detect and no amount of up-sampling or post processing tricks will change that.
As I pointed out to you in another comparison between a D800E and an IQ180, there will be cases when the higher res superior system does not display any noticeable advantage.
I doubt you will even see noticeable different at 30x40".
You can doubt it, or you can compare actual prints as I have done.
I upsampling 5D3 file to match to D800 size and would have pixel peeping to see very small difference. I have a few 20x30" prints from 5D1 and 5D2 and honestly I even don't see much difference either. The difference between D800 and 5D3 is far less than between 5D2 and 5D1 according to DXOMark system test (lens+sensor).
I read bunch of photogeraphers such as Hans Kruse who truly don't have agenda and widely respectied photographer said they don't see much difference. I'd rather believe him than you.
Again, I have pointed out that Kruse was happy to exaggerate the difference between the D8002 and HD-40, which shows even less disparity than the D800 and 5D3 comparisons. Even as the the reviwer,
Alex Koloskov, said the difference would not be noticeable on even a large print, Kruse insisted that the differences were significant.
That makes Kruse biased IMO.
My processed samples are directly out of CS6 by upsampling 5D3 file to D800E size and all others are the same default/Zero setting that everyone can duplicate. Or you processed D800E RAW and I process 5DIII RAw and let's compare?]
To be honest you're strongly Nikon biased from many have seen in your posting history.
I would disagree. If you have looked at my posting history, you will notice that on the Nikon forums, I have been a fierce critic of Nikon, and even been dismissed as a Canon fanboy.
And are you seriously going to deny that you are not only strongly Canon biased, but entirely?
Sure I only shoot Canon but I have seen enough D800/D600 photos and I don't see they are much better in IQ overall.
But don't you realize how weak that sounds when you are comparing your limited experience with D800/D600 photos to someone who shoots both systems all the time and in all manner of
I have read others who widely regarded as honesy and not brand binded as Galland (may not spell his name correclty). He is 5D2->D700->D800->5D3 shooter and he has true professional bussiness. He also said there is no much difference and he switched back to 5D3 because it has better AF.
I would like to read Galland's comments and find out what kind of shooting he does. If AF is critical to his needs, then I suspect the D800 might not have been practical for him anyway.
Of course they do, but you still remain determined to argue a losing argument.
I don't see I am losing except you perceive I am
I never said there is no difference but ONLY dispute it's not big when you expose correctly or ETTR in DR and even in resolution when you use some best lenses that is confirmed by DXOMark test.
Again, if you expose correctly and ETTR, the advantages of the D800 will only be widened IMO. And the DXOMark test still gives the D800 a good 6 mpx advantage over the 5D3.
