TN Args
Thank you for self-checking and saving me the trouble of explaining the error in your field map comment above.Oh there are all sorts of issues with testing, and not having (1) a reasonable sample size (one lens certainly doesn't do it) that have been (2) obtained through normal commercial channels (i.e. not possibly cherry-picked by the manufacturer or regional distributor) are certainly real issues, as are the facilities for proper tests. What can I say other than: the more data of at least decent quality, the better.Other than the gold standard lensrentals blog who have access to skilled technicians, proper testing gear and best of all multiple samples of lenses. Alas they don't do much reviews :-( Most of the "test" sites have their problems . I like Dustin Abbot { blog and YT } and Christoper Frost { YT } who give a decent idea of performance . Though of course based on one sampleNo doubt reducing any complex data set to a single number is prone to less useful or even misleading results. But (1) that single sharpness score is not totally meaningless, and that the Sony 24-240mm scored so much lower than any other FE lens they tested is somewhat remarkable. And (2) discussions about DxO data over the years have made me think that a lot of people like such single-number scores and most don't want to do what they really should do, which is drill down a couple of levels into the underlying results. Sometimes dumbing-down is marketing-driven; but at least DxO offers you the choice to look at either.I would not give their sharpness score much merit they provide very good data summing it up in one number is a bit daft.Among the 32 FE-mount lenses that DxO has tested, the Sony 24-240mm achieved by far the least sharp / lowest resolution, at least by the somewhat simplistic metric of DxO's overall 'sharpness' score. Go toSeveral things:
- The 24-240 isn't the sharpest lens to begin with, so manage expectations
Well I have looked, and alas the answer is more complicated than I recalled.I did not know that , I had assumed that selecting a given camera gave results for that sensor MP count . You know what they say about assumingYes, to a degree. The problem is, IIRC, DxO's maximum-green field map coloration represents the maximum that a 12 MP sensor--yes, only a twelve megapixel sensor--can really benefit from. On one hand, with a maximum-quality 12 MP,Their sharpness test data, field map is I feel a good indicator of performance![]()
The percentage scale is the lens acutance (in perceptual MP) as a percentage of the sensor MP.DxO's 'perceptual megapixels' scale tops out at 12 P-MP, above which is the maximum score:
However, the "Field map" we were discussing seems to be something somewhat different:
I have not yet determined what "Acutance map for use case", expressed as a percent, means. Does that mean it's related to the resolution of the sensor on which it's tested? Apparently so. Or I should say, obviously so putting the same lens in front of an APS-C versus a FF sensor. Beyond that maybe. I checked the Sony 24-240mm, and pulled up 240mm @ f/6.3 for the A7R (original) versus the A7R IV. The plot is clearly more favorable for the A7R IV than for the A7R. I guess that is showing that even a mediocre lens benefits a little from a higher-resolution sensor. But beyond that, I'm not sure precisely what the plot is showing.
Hence, as you say in your correction above, a higher resolution camera of the same sensor size will result in a different and ‘less green' field map for a given lens.
cheers
