I don't shoot macro. Therefore, never tried to understand the specs. My only interest in a lens that says 'Macro' is its ability to focus a bit closer than the non-Macro lenses.
But this question lingers on.
What is the actual definition of the Macro/Reproduction ratio give in the specs?
Internet search result says:
"Magnification Ratio = Image size on sensor : Actual size of subject"
Let's say there is a bug that is 17mm x 13mm in size and its image fills the mft sensor 100%. I understand this as 1:1 macro. Correct?
Let's say the same bug when shot with a FF camera also fills an area of 17x13mm. That lens should also qualify as 1:1 macro. The fact that FF sensor area is approximately four times that of an MFT sensor, and that the image does not fill the entire sensor, does not matter. Correct?
While this question was on my mind for a while, the debate in the comments of Olympus 50-200/2.8 lens announcement article has increased my curiosity to understand this. I don't understand the logic to specify a different ratio as "35mm equivalent". That would be necessary if the ratio was of sensor size itself, not if the ratio is of the captured image size.
What am I missing?
Thanks.
What am I missing?
Thanks.
