Just buy an FF camera and have done with it, if that floats your boat. It will do things an M43 camera cannot do. No amount of bizarre defensive techtalk will ever change that. I would not be in the least bit surprised if FF was the dominant format in five years’ time, with a couple of APS-C and 1” specials for the long-reach crowd and everyone else using very capable smartphones. I like M43 but Olympus versus rest of the world is a bit of a foregone conclusion, isn’t it.
Buying FF does has a sense, but only after the FF will have the number of pixels 4 times more than m43, and the lenses will be as good as those for m43 in terms of the absolute resolution. Otherwise the two systems have their advantages and disadvantages with respect to each other depending on a task.
For example, the larger pixels density and exellent tele-lenses (like Oly 300 f/4) in case of the m43 make this system to be significantly better for the world-life photography than FF systems I know. Also the excellent pro lenses like OLY 17 mm f/1.2 allow for m43 to compeet with FF at low light. I do not know f/1.2 lens for FF that is perfectly sharp across the frame (Oly 17 f/1.2 is indeed increadebly sharp at f/1.2). Even at f/2.8 FF lenses are so-so according to my criteria.
The higher dynamic range of FF sensor is only significant if we are looking at an image at the1:1 size or capable to see all the resolved details. But in majority cases, if you are interested only in the full-frame view you can downsample the m43 image and increase the dynamic range. For example, the down-sampled m43 image from 16 Mpx to 4 Mpx will have the same dynamic range as 16 Mpx FF-image. From my experience 4Mpx images printed on the A5-size paper are hardly distinguished from the 16Mpx ones in terms of the visible detailes. The properly downsampled photo looks better if printed at proper size.
The proper downsampling can also be important in future, when FF-sensors with huge amount of pixels (~80 Mpx) will be typical.
I am sure that m43 system has the Future.
