Guy Davis
Member
Kevin,
I just tried "f" below on my 10D and exposure is determined at full shutter press in One Shot mode.
In the process of testing this feature on my camera I think I found a bug in the Custom Function setting for CF4 version 1.0.1. I'll start another thread to discuss that.
This looks to be about right! I think it is also important to noteHere's a summary (I think) of what's been discussed:
Method/Exposure determined/Focus determined
a) CF4-0 with AI Servo/at full shutter press/at half shutter press
b) CF4-1 with AI Servo/at half shutter press/while ' ' is pressed
and held
c) CF4-3 with AI Servo/at full shutter press/while ' ' is pressed
and held
d) CF4-0 with One Shot/at full shutter press/at half shutter press
e) CF4-1 with One Shot/at half shutter press/when ' ' is pressed
and released
f) CF4-3 with One Shot/at full shutter press/when ' ' is pressed
and released
Advantages:
a) Does not require a thumb (good for dogs with 10D). Don't have to
know where the "menu" button is.
b) Allows for recomposition of image after having locked metering
on a specific point. Can focus using recomposed image.
c) Allows independent control of focus
d) same as "a"
e) same as "b"
f) same as "c"
Feel free to suggest other advantages for each method and point out
any corrections that should be made to the Method table.
that AE operates the same with AI Focus as it does with One Shot
(at least I'm pretty sure).
What I am not sure about, is Item f . Have you tried this to
verify that no matter the AF mode, AE occurs with a full press?
Could you let us know?
Thanks,
Kevin V
One of the greatest things I have ever learned is to:
RTFM
http://www.pbase.com/kevinv
