skipcooney
Member
The manual for my EF-S 17-55mm f/2.8 IS lens says "When you use a tripod, the Image Stabilizer should be turned off to save battery power." However, I have a low end tripod, Silk U9000, and I know there is slight camera shake when the shutter releases, even using a cable release. I saw this shake when I taped a laser pointer to the camera. I figure I should just keep the IS turned on when using the tripod. Anything wrong with this approach?
