Looking for help with Lightroom upgrade
zim4321
Well-known member
Westchester, NY, US
I recently did a major upgrade. Full new system - Custom Built to be able to handle LR well, and also upgraded from 6.14 to 9.2 so I feel I have a lot to learn.
Firstly where can I get the best recommendations on how to best configure LR to operate at its' best? I did go in to Edit/performance and Checked the Use GPU for Image Processing, then Custom - it shows my Nvidia GTX Super 2060 Card with 8GB
I took the HDD from my old PC where all of my photo's are stored, and also my catalog.
I downloaded the new LR (I am on a 7 day trial). and pointed it at my Catalog and it converted it (yes I backed it up first). H: is a new 4TB HDD. F: is my old 2TB HDD where ll my photo's are. I then Copied the catalog onto my C: drive into a new folder - Photo, and renamed it LRcat 9, figuring it Should boot drive (which is the much faster 1TB NVMe drive? My Catalog is almost 2GB.
My current camera is a D810 and I shoot raw.. on my old system it would take 5-10 seconds to open, now it is faster - but I did not expect to have ANY lag on this new system, as I thought what I bought was close to the top of the line.
so my first question is; Where can I learn the best way to optimize and setup my hardware and software to be most efficient?
my second question - is looking for recommendations for instructional video's to learn about the upgrades between LR6 and LR9.. there are new controls, etc.
I have been using lightroom since I think Version 2 or 3.
all help and recommendations are very welcome! my old system was 9 years old with no graphics card - so this should be a huge upgrade. I also want to add Topaz Denoize but feel like I first need to get what I have under control.
Happy to share any other info - just ask.
I bought a Dell 4K U2720Q monitor. I am using my old Dell 22" as the 2nd for now
  • Define R6 USB-C Blackout, No PSU, E-ATX, Black, Mid Tower Case
  • Asus TUF GAMING X570-PLUS (WI-FI), AMD X570 Chipset, AM4, HDMI, ATX Motherboard
  • Ryzen™ 9 3900X 12-Core 3.8 - 4.6GHz Turbo, AM4, 105W TDP, Retail Processor
  • EVGA GeForce® RTX 2060 SUPER™ VENTUS GP OC, 1470 - 1665MHz, 8GB GDDR6, Graphics Card
  • Kingston 32GB Kit (2 x 16GB) HyperX FURY DDR4 3200MHz, CL16, Black, DIMM Memory
  • Seasonic PRIME Ultra Platinum, 80 PLUS Platinum 750W, Fully Modular, ATX Power Supply
  • Noctua NH-D15 chromax.black, 165mm Height, 220W TDP, Copper/Aluminum CPU Cooler
  • Diamond 7 Carat, 1.5g, 4.5 (W/m-K), Micronized Diamond, Thermal Compound
  • Corsair 1TB Force MP600 2280, 4950 / 4250 MB/s, 3D TLC NAND, PCIe 4.0 x4 NVMe, M.2 SSD
  • ROSEWILL RDCR-11004, Internal, 5.25" Bay, All-in-one, USB 3.0, e-SATA, Card Reader
  • Seagate 4TB IronWolf Pro ST4000NE001, 7200 RPM, SATA 6Gb/s, 512e, 128MB cache, 3.5-Inch HDD
  • Standard Wiring with Precision Cable Routing and Tie-Down
  • Windows 10 Pro 64-bit DVD OEM
reported system info from LR Help
Lightroom Classic version: 9.2 [ 202001311240-2d026470 ]
License: Creative Cloud
Language setting: en
Operating system: Windows 10 - Business Edition
Version: 10.0.18363
Application architecture: x64
System architecture: x64
Logical processor count: 24
Processor speed: 3.7 GHz
SqLite Version: 3.30.1
Built-in memory: 32681.5 MB
Real memory available to Lightroom: 32681.5 MB
Real memory used by Lightroom: 9647.9 MB (29.5%)
Virtual memory used by Lightroom: 16205.2 MB
GDI objects count: 973
USER objects count: 2495
Process handles count: 2909
Memory cache size: 9870.4MB
Internal Camera Raw version: 12.2 [ 384 ]
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2,AVX,AVX2
Camera Raw virtual memory: 3706MB / 16340MB (22%)
Camera Raw real memory: 3712MB / 32681MB (11%)
System DPI setting: 168 DPI (high DPI mode)
Desktop composition enabled: Yes
Displays: 1) 3840x2160, 2) 1680x1050
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
DirectX: NVIDIA GeForce RTX 2060 SUPER (26.21.14.3200)
Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic
Library Path: C:\Photo C\GZ LR9.lrcat
Settings Folder: C:\Users\garyz\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) AdobeStock
2) Facebook
3) Flickr
4) Nikon Tether Plugin
5) SmugMug
Config.lua flags: None
Adapter #1: Vendor : 10de
Device : 1f06
Subsystem : 30673842
Revision : a1
Video Memory : 8031
Adapter #2: Vendor : 1414
Device : 8c
Subsystem : 0
Revision : 0
Video Memory : 0
AudioDeviceIOBlockSize: 1024
AudioDeviceName: Speakers (3- Realtek(R) Audio)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: 12.1x4
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 16
GL_ACCUM_BLUE_BITS: 16
GL_ACCUM_GREEN_BITS: 16
GL_ACCUM_RED_BITS: 16
GL_ALPHA_BITS: 0
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_SIZE: 32768
GL_MAX_TEXTURE_UNITS: 4
GL_MAX_VIEWPORT_DIMS: 32768,32768
GL_RED_BITS: 8
GL_RENDERER: GeForce RTX 2060 SUPER/PCIe/SSE2
GL_SHADING_LANGUAGE_VERSION: 4.60 NVIDIA
GL_STENCIL_BITS: 8
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 4.6.0 NVIDIA 432.00
GPUDeviceEnabled: false
OGLEnabled: true
GL_EXTENSIONS: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_minmax_factor GL_NV_blend_square GL_NV_clip_space_w_scaling GL_NV_command_list GL_NV_compute_program5 GL_NV_compute_shader_derivatives GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_conservative_raster_pre_snap GL_NV_conservative_raster_pre_snap_triangles GL_NV_conservative_raster_underestimation GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_barycentric GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_memory_attachment GL_NV_mesh_shader GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_representative_fragment_test GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_scissor_exclusive GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_float64 GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_shader_texture_footprint GL_NV_shading_rate_image GL_NV_stereo_view_rendering GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
Try this new feature when you import.
Lot's of good stuff in that optimization link. When you read further down it recommends in which sequence to work. Also turning Lens Corrections helps particularly with Healing. Since getting my new 2019 iMac it flies and I don't need to follow any process.
Here is list of the changes. You can also scout out pages 1-3 of the blog for current changes. This long is from March of last year. You can go further back for more specifics. LR7 starts on page 9.
Some of the big changes. Presets where changed from lrtemplate to XMP so thet can be shared with PS.
Dehaze and Texture sliders.
You can now hide presets. Right click on the + and manage.
Develop panels are now configurable.
Enhance Detail is new
Process version 5 corrected blacks that looked purple with high ISO.
Auto in the basic Panel is now very usable. Called Sensei and is AI that is continually being trained. It is pretty good but once in while has a brain fart. I use it all of the time.
new colour Profiles. Adobe Colour is now the default. The new Sharpening default is not 40.
As you can see some things were moved into the Basic panel which is more convenient.
Version: 10.0.18363
Installed Plugins:
1) AdobeStock
2) Facebook
3) Flickr
5) SmugMug
Device : 1f06
Revision : a1
Video Memory : 8031
Device : 8c
Subsystem : 0
Revision : 0
Video Memory : 0
Build: 12.1x4
GL_ALPHA_BITS: 0
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_RED_BITS: 8
GL_STENCIL_BITS: 8
OGLEnabled: true
Nice new rig, congratulations :-)
While LR 9.2 will definetely be a LOT faster on your new machine than LR 6 on your old, you should know a few things about LR:
1: The primary performance optimisations done in LR are in import/export/preview rendering. The difference will be HUGE when doing those steps. It was good on the same hardware, so with new hardware as well... Thunderbolt city :-)
2: The "other" optimisations are mostly focused on harnessing the power of modern GPU's for most of the development tasks. The difference is almost equally huge on that account, BUT: (And this is a huge BUT).
That performance gain in develop is really only for 4K screens and more. With your upgrade you have bought a 4K screen, and that will now peform decently - probably a little better than your old machine on a full HD screen.
I know - a bit dissapointing, but you shoud try LR 6 on a 4K screen.... OMG what a dog - horribly horribly slow. So it is A LOT better - but your upgrade also included a 4K screen which effectively negates most of the subjective performance expectations with a new machine.
Performance on 4K can still and probably will be improved further in the coming years.
So - maybe not as much as you expected, but remember 4K is four times FullHD, so already it is 4 times+ faster in develop just because of your resolution change.
Import is Hugely faster... became painfully slow when I upgraded to the D810 about a year ago.
Thx!
Thank you very much for the info - I will going thru all of it!
