wizofoz
Well-known member
G'Day Jeff, thanks for your input.Don’t waste money on expensive lens adaptors. I’ve adapted many lenses from various systems… Nikon AI-S, Pentax SMC Takumar, Voigtländer M and L39 mount, etc…Hi all
A few days ago I made an impulse buy of a Om EM10 mk1 and a pair of lenses, 14-24 f3.5 -5.6 and 40-150 f4-5.6.
I did it for a couple of reasons -
I know as much as anyone about the Pentax system, but bugger all about any other. I'm looking to expand my knowlege of the OM system, tips and tricks, good places to find info, anything you old hands can point me towards.
- it was relatively inexpensive , under $600 Au
- I have been thinking about some lighter weight gear for some time. My Pentax K-1 is a magnificent beastie, but bloody heavy and being now in my 66th year I'm not a strong as I used to be.
- Its a new toy to play with
For instance, I have ordered a 'dumb' PK to M43 converter so I can have a play with my collection of Pentax lenses on the EM10. Is there anything I need to do in camera to make that work? I have a dozen or more Takumar's and other off brand manual focus lenses I'm keen to try. I wonder what the helios will look like on this small sensor?
I get dumb adaptors (no lenses or electronics) from FotodioxPro.com. If you really like the experience,
M4/3 magnified focus assist is a revelation compared to optical viewfinders, the adaptors are cheap enough to be able to get one for each lens. I found that juggling lenses AND adaptors was such a PITA, I decided on dedicated adaptors for each lens.
The f-stop stays the same, but the depth of field doubles. f2.8 stays f2.8, but DoF is f5.6.I understand the crop ratio will be 1/2 compared to my full frame camera, so the 40-150 is effectively a comparable FOV to an 80-300, but does that also aply to F stops? Do I lose a stop of light, so that f4 on the lens is equivalent to f5.6 of a FF lens? or have I got that wrong?
I bought a K&F adapter, no contacts, no electronics. I have a dozen or more M42 and K mount prime lenses (and a M42-K mount adapter) and probably the same amount of zooms I can use in full manual mode. Maybe one day I'll get a speedboost type adapter, or something else with electronics, but this week, start simply.
I'm used to MF focus assist and magnified focus assist from my K-1. I use it all the time when focusing landscapes, etc.
I had a search through the EM10 menu following your comment, and now have it assigned to one of the function buttons. Cheers!
