Hi,
It seems very strange, but I have not found a correct DOF calculator. For some reason the ones I found all have the same error. Of course at first I thought that I was wrong. But it seems I am not.
When I try to use the calculators, you have to enter:
Focal Length
Aperture
Distance to the subject
So far so good.
Now bare with me. Next is sensor size. When I take a photo with:
50mm
F1.4
10 meters distance
With a full frame sensor. This gives X cm DOF.
Then I crop that image with a APS-C factor in post.
So the image was ~35x24 and I crop out ~24x18 in the center.
The DOF in cm does not change imho.
Why then, when I use the DOF calculators on the internet, does the DOF change when you have a different sensor size. In all calculators I encountered, the DOF of a medium format sensor is less shallow that a Micro 4/3 sensor at the same distance.
Shouldn't it be the same when the aperture, lens, and distance to the subject are the same? Just more of the environment is in the picture with medium format?
I am confused, I would like to know if I am correct. And maybe someone can point me to a correct calculator?
Focal Length
Aperture
So far so good.
50mm
F1.4
10 meters distance
