...just as handy instead would be
a slide off pentaprism like the one my Canon F1 35+ years ago.
Or a lift-off pentaprism, like the one on my Nikon F, 40 years ago.
But, am I the only one to notice the confusing mix-up in terms? The OP said "LivePreview". Somebody else says "LiveView". You and I use "EVF". If you read the associated text carefully, it seems that some people are confused! There are multiple types of cameras that have these important features:
1. Optical dSLRs with mirror-up mode to drive the LCD with primary sensor data and an OVF.
2. Optical dSLRs with secondary sensor to drive the LCD and an OVF.
3. Electronic eSLRs that drive both the LCD and EVF with primary sensor data.
4. Electronic prosumer/super-zoom DCs that drive both the LCD and EVF with primary sensor data.
5. Electronic compact DCs that drive the LCD, and which have a separate optical VF.
6. Electronic compact DCs that drive the LCD.
There are also multiple variations on these 6 "themes". For example, the location of the LCD and the degrees of freedom of movement of the LCD. And the variation in the design of the pentapriism/pentamirror, which affects the quality of the image in the OVF. And the design of the EVF which affects resolution and brightness.
There are so many variations. I'm sure that each of us has a different experience, so come to the discussion with vastly different ideas about what is good/bad & right/wrong. Combined with those different terms (LivePreview vs EVF), we are talking about quite different things, I believe. And doing so passionately! And occasionally getting upset (that someone doesn't seem to understand and agree with what we say).
Charlie Davis
Nikon 5700 & Sony R1
CATS #25
PAS Scribe @
http://www.here-ugo.com/PAS_List.htm
HomePage:
http://www.1derful.info
'I brake for pixels...'
