Thanks very much for taking the time!One last thing....(still reading through my notes!).
Since Paul released a new version of his Linear Workflow action yesterday, I took a whole bunch of raws and converted them to give his action a workout. His recommended conversion is EVU, so I used that. I did notice some things that I will have to go back and investigate further, doing some comparisons.I mentioned that I was seeing more and more problems with the Canon
conversion. Some of these issues are sadly inherited by the linear
conversion. With the 10D, at least, there is a green channel
"weirdness" that can show up in odd places. It has to do with the
white balance routines. Capture One is extremely clean in this
regard. It's been widely reported.
Yup. Both the linear and c1 seem to bring out a bit more detail. Something that I am sure would be noticeable on larger prints!OK, I next cropped out a small portion at 100% to show that the
linear is surely capable of bringing out some more detail than the
non-linear. Compare the window at the far right.
But, but, but.... more importantly, Capture One doesn't have the
little green/blue "uglies" that you can see in the Canon
conversions. Look at the clapboards right above the center window
in the second image. Is this unique to the 10D? I don't know. It
surely doesn't show in D30, D60, or 1D files I've seen.
Based on the 38 pics I worked with last night, I would say YES. I noticed this "effect" in a couple pictures, and in one at least, it was fairly distracting. I think it would be noticeable in 8x10s. 4x6s, maybe, maybe not. I should print one to see. Neither c1 nor ACR show this in a conversion of the same file.Does the 300D show the same thing? Don't know.
If this pic ends up being a small web-sized version or a small 4x6 print, no, of course not. No point worrying about something you will never see. But if you are going to print large or view bigger versions of the photo, then for me at least, the answer is yes, it IS important. I would prefer to get the cleanest picture I can. In MOST of the photos I played with last night, I didn't have too many issues, but I need to do more, direct comparisons to be sure.Is it important? Only you can decide.
Don
