Lexar Memory sticks available at techstore!
I just received my memsticks from techstore.
listed on the packaging is a 100% compatability guarantee to any CAMERA that uses a memory stick / 5yr limited warranty. also states "tested in digital cameras,mp3 players,and other devices from Sony corp.
Of course I have nothing to put them in.......
Bill
over 1900 32mb MS's in stock
over 900 64mb MS's in stock(minus one :)
32mb - $66.08
http://www.techstore.com/ts/spec_info.asp?sku=460LEX987
64mb - $112.79
http://www.techstore.com/ts/spec_info.asp?sku=460LEX988
MP3 player ? Hhhhmmm, that means Sony allowed them to copy music too, it has a built-in copy-protection in short. In other words ... its Magic Gate compatible too! Thanks for the info. Bill, just what I needed to know.
Hmmm. I guess I would buy them too if I were sure they fit in the DSC-F505V. Do the dimensions/specs look similar to the following specs for the 32MB memory stick from the Sony web site (i.e., the size and shape of a stick of gum)?
Memory Type: Flash memory (MSA-32A: 32MB)
Connector: 10-pin
Interface: Serial
Operating Voltage: 2.7V to 3.6V
Power Consumption: Average: Approx. 45mA; Standby: Approx. 130µA
Access Speed: Writing: Maximum 1.5MB/second; Standby: Maximum 2.45MB/sec
Operating Environment: 0°C - 60°C (non-condensing)
Dimensions (LxWxH): Approx. 21.5 x 50 x 2.8mm
Weight: Approx. 4g (0.14 oz.)
Supplied Accessories: Memory Stick Storage Case, label, operating instructions
Thanks in advance!
I got am s70 and one of thouse 64 sticks... great deal on both, and both available overnight. I have the Sony 64 backordered, but for now this one works fine in the s70...
Connector: 10-pin
Interface: Serial
instructions
Thanks in advance!
It is completely compatible (it is a Memory Stick - not a Smart Media). It is physically identical to a Memory Stick (I have two Lexar sticks - rec'd today from Tech Store).
The box labels it as "Lexar Media High Performance" and "Memory Stick".
The box also says "100% Compatibility Guaranteed, Plus 5-Year Warranty". Below that is says "...100% compatible with digital cameras that use Memory Stick". It also indicates it is not compatible with music devices that require security encryption support which presumably means it is NOT MagicGate compatible.
I don't have any regular memory sticks to compare against and I'm using it in an MSAC-FD2M floppy adapter in a FD-95 and I think the FD2M has more limitation than the actual memory stick so I can't tell you if it is really 4-8 times as fast as Sony media. It did format in my computer in just a few seconds, though (I'm using 32MB sticks).
I went to the Lexar Media web site, but could find no reference to a
memory stick. Maybe I was just looking in the wrong place.
Is this product the same as the SmartMedia flash memory card?
Their "compatibility matrix" doesn't list the DSC-F505, so I kinda wonder
about that.
