cerj
Forum Enthusiast
Yes, I agree, seems heavy. I may hold out fo something that adds less bulk.Nice. I might have to get that SmallRig L bracket as well then. And for only about $50 it's a good deal too. Just seems a bit heavy.I checked with “Smallrig” to ensure the FTZ adapter could be put on and off the camera without removing the L bracket, their response:Yes, all of the lenses I'm talking about here do not have tripod collars and most are relatively small and light so I don't think it will be an issue using the L bracket in lieu of the FTZ adapter. The best solution for me will be for Nikon to hurry up and release the 14-30 f4... that will reduce my need to use the FTZ tremendously.Probably always best to use the lens tripod collar if it's available, instead of mounting to the FTZ adapter or Z body.I'm thinking about doing exactly this.... using the Smallrig L bracket without the FTZ support except for heavier lenses that require it. Which brings up a question.. is there an actual list or if not a guideline for F mount lenses that shouldn't need the FTZ tripod support?No, I can just see that the front of the bracket is flush with the camera's front face, so there is room for the FTZ to rotate. On top of that it rises the whole camera 16.5 mm allowing the FTZ to rotate without touching anything below the plane of the lower face of the bracket.Wait, you've tested this out with a Smallrig plate already?That is precisely what the SmallRig solution does. They sell it like a feature to solve the pinky issue. For me it solves the FTZ problem.
They sell it as "add 16.5mm height based on the original handgrip for pinky support" but the main advantage is the FTZ having room to rotate to be removed.
You can see it here, just suppose the FTZ support is not installed:
Rendering Smallrig with FTZ support.
Thanks for your message.
Yes, our L bracket for Nikon Z7 allow the FTZ adapter can be mounted and un-mounted without removal of the L bracket from the camera.
Thanks very much.
Have a nice day!
