Tord S Eriksson
Ah, the K-5! If it wasn't the AF I would still be a Pentax fan, but even the tiny Nikon 1 V1 outperformed my K-5 in every way when it came to startup time and AF!Hello MighthyMike
I wrote that my K5, K1 and KP don't do that, so why do you think I can't demand that from an AF-C? And of course my camera knows what I want: I use only one AF point and when I focus, the camera knows that this AF point needs to be brought into focus. This is a very simple application!You're asking an algorithm to track something that isn't moving except that the algorithm is expecting movement so now its confused, it doesn't know what you want in focus because the item you've focused on isn't moving. Computer algorithms are far simpler than our eye-brain communication, you can't expect them to read your mind or to figure out that you don't want it to do what it was programmed to do. Why else would there be at least two AF choices available, one for moving subjects and one for static subjects!
For example a good result test of the K3 III AF-C:
AF-C with the first image set to focus priority:
So to test, point the camera at a static object (which is out of focus) and press down completely the shutter release button:
- the K5 almost never focused good on the object, it always released the shutter far too early (the AF motor was still running and after the picture also). The K5 was unusable here and you always had to wait until the AF motor came to a standstill and than you could press down completely the shutter release button.
Never tried the K-3, sadly.- the K3 III is excellent here, the images of my static subject are in this test excellent in focus !
AF-On is something I have on all my Nikon cameras (except the Nikon 1 cameras), a blessing, definitely!
