The difference in detail between a K100D with a good lens and any 10MP APS-C camera is absolutely minuscule IMHO, not even worth worrying about. There's only a significant difference once up to 12MP full frame.
HiJpegs from the K10 were dull and lifeless and with an inordinate
amount of fine noise even at ISO400 - I was shooting flowers etc in
slightly overcast and windy conditions, hence the higher ISO
settings. When the sun emerged and the wind died down I tried lower
ISO and adjusting various in-camera settings but still the shots were
mundane at best. So I switched to RAW and P/Pd using both CS2 and RSE
but still there was something fundamentally amiss with most of the
shots. I wondered if it was a duff model as I tried comparison shots
with my DS and the latter's results were much better overall.
Having read so many glowing reports about the K10 and seen so many
examples posted here of really sharp and vibrant images I really
hoped the K10 would be my next purchase and simply couldn't
understand what, if anything, I was doing wrong. I like tro think I;m
reasonably competent but achieving similar quality shots was eluding
my best efforts. I appreciate a day isn't long to get to grips with
any new model but some of the friend's shots, to be honest, looked
equally lifeless to me although he seemed content with the results.
Assuming this could have been a Friday afternoon assembly line job
and most K10s are excellent, should I be seeing a huge difference in
image quality over my DS or am I expecting too much?
I'm really unsure what to do next as I'd like to upgrade from my DS
and the K10 did seem the logical choice until this disappointing
experience. Any guidance or thoughts would be appreciated. Sadly none
of the images survived a recent computer upgrade (lesson learned
there - my other stuff was backed up on CD) or I would post examples.
The mind is like a parachute, it works best when open.
neil
So buying a K100D (not sure the new K100Super has any advantages for me as the extra features of image doctoring in-camera would never be used) I should see an improvement in jpeg IQ over the DS but comparing this with the K10 using my existing lenses, you believe I'd see little if any improvement?Also, the higher sensor resolution of the K10D makes lens quality
critical. At the 6MP resolution of the K100D lenses need only be
good; to maximize the K10D's IQ they must be excellent.
A while back I compared my DS jpeg images (18-55 & 50-200) alongside a borrowed D80's at 200/400 and the D80 seemed to have less noise and a generally smoother appearance, which may well be down to its internal jpeg processing. Its RAW images certainly looked to have more clean and crisp detail, which is why I'd presumed the K10 would perform similarly, but this was proven not to be the case. The D80 required more thought to protect highlights but I was impressed with its qualities using the 18-70 and IS18-200. It would be interesting to compare its results with a prime (expensive) lens and a K10 also so fitted.10 is definitely worse than 6 in terms of noise, but not in terms of
resolving detail.
10 is better at resolving detail on great lenses. Par on average
lenses.
It was with all lenses. I realise the tendency to underexpose will put shadow detail at risk when brightened and may emphasise noise but I found the borrowed D80 didn't produce these shadow patterns when I deliberately underexposed with that and subsequently brightened the shots.Just curious but was the noise at 400 with the Vivitar? if so could
it have been underexposing hence the greater noise?
Well there you go, somebody on a forum said it. And you said it again (on a forum, no less). Fact established.As many on the forums have pointed out, this is simply not true. The
K10D's JPEG engine works wonderfully if you bother to calibrate it
correctly...
Great, glad to hear it. If you read my comments I never addressed this question. What I said is that better lenses are required to really expoit the K10D's detail advantage. Which seems to be exactly what you are stating, as well, below:The 18-55 kit lens looks no worse on my K10D than on the DS to me.
Again, I never said that 10mp harms lenses, just that you need really good ones if you hope to exploit what advantage 10MP may bring.The FA43 f1.9 ltd can't fully show it's capabilities on the 6mp, but
I don't think the 10mp harms existing lenses (at least not in a
noticable way.)
Detail resolution is precisely what noise replaces in a digital image. You can only hope to resolve more detail with a K10D with the aid of both decent light and a really good lens. These are my points. In your haste to refute them, you managed to neatly restate them (see below):10 is definitely worse than 6 in terms of noise, but not in terms of
resolving detail.
Assuming decent light, of course10 is better at resolving detail on great lenses. Par on average
lenses.
K100D Super brings the flourine anti-dust sensor coating, the sensor-shaker, and compatibility with the new SDM lenses. As far as I know there are no other differences.So buying a K100D (not sure the new K100Super has any advantages for
The D80, as all current Nikons, has a good jpeg machines. That and quality glass, metering and AF makes for great pictures. And it's not that the K10D is an inherently poor performer--quite the opposite, in fact--just that its jpeg engine leaves a bit more on the table (which can be remedied RAW processing).A while back I compared my DS jpeg images (18-55 & 50-200) alongside
This would suggest there's little advantage in my going for the K10D at present.K100D Super brings the flourine anti-dust sensor coating, the
I think you will see an improvement in jpeg mode with your existing
lenses with either camera as compared to the DS. The DS's jpeg engine
is not nearly as good as the K100D's, and although the K10D will be
limited by your glass it will be limited at a level of IQ greater
than your DS can deliver. It just isn't likely to be a convincing
improvement over the K100D where IQ is concerned. And in low-light,
it may in fact be worse.
Interested to see your lens line-up. As mentioned, I have the first two on your list and although I've been seriously looking at my Pentax body options, my instincts are starting to direct me toward that D80 with suitable glass and a decent Nikon flashgun as my Vivitar flash is a very hit and miss affair. Even if I went for the genuine Pentax guns, threads here would suggest these leave a lot to be desired whereas the Nikon system seems highly rated by all and sundry.The D80, as all current Nikons, has a good jpeg machines. That and
Pentax K100D w/DA18-55 & 50-200, FA50-1.4, and Tamron 70-300Di; Panny
LZ3
